Results 11 to 20 of 23
Thread: DOS File Level access to Secondary (370H) FDC - Driver Nightmares
    33,390
    That'd be a rewrite--CP/M file system organization is very different from DOS FAT.
    33,390
    Sprechen Sie x86 assembly? I might have something that could be modified.
    Not exactly, I learned assembly on the Z80 but that was years ago. I guess now's as good a time as ever to learn. Having a place to start by modifying some existing code would be wonderful.
    You would really need a device driver which accessed the secondary floppy controller (370h-377h) for DOS to see the drives since PC BIOSes only access the primary controller for INT 13h access which is what the DOS builtin disk driver uses. Even then DOS may not recognize the disks since they aren't in a standard floppy format (160KB, 180KB, 320KB, 360KB, 720KB, 1.2MB, 1.44MB, 2.88MB). I don't recall a specific media descriptor byte code for 8" floppy drives though there were two old unused codes (FAh and FBh).
    Would it be possible to use a null modem serial cable to transfer over whatever data you have from whatever computer used the 8" floppy drives to a PC ? Seems like that would be easier than trying to get an anachronistic device from the 70s to work with a PC from the 80s.
    33,390
    That's what I offered. Other than using the standard DMA2, IRQ6, the code allows for specifying the FDC base address.
    I have a little experience in this. Said code that I was looking at was for an Eagle 1600 DOS driver. Since I don't know what 8" format was used (I seem to recall that there were two), you'd have to figure that one out and change the device parameters and recompile. I've got a similar driver for NEC APC 8" floppies, but I don't think the native SCP 86-DOS ones were the same.
    Sounds perfect, I'm sure I can figure it out from there
    And remember if you get something working sharing is caring!
    Of course. I haven't started in on it yet because there's going to be a bit of learning curve, but rest assured if I get a working binary to build I will post it.
    Starting to awaken from the nightmare. A certain resident floppy disk expert here (you may know him from his eponymous XT-IDE mod) has handed me a powerful floppy disk I/O library and a nifty DOS block device driver template to wrap around it. I've managed to get a proof of concept driver working that allows file level access to a bog standard DS/DD 5.25 disk on a secondary FDC. All the heavy lifting for toggling the DMA bit in the DORs of the primary and secondary controllers was already implemented in the library, so it's even able to copy files back and forth directly between drives on different controllers.
    The main issue I'm having right now is how to handle turning the motor(s) off on the secondary FDC. The primary FDC uses a timer in the BDA to shut the motor off after a certain period. The BIOS of course doesn't service the secondary FDC so that method is unavailable. Currently I have the driver turning the secondary motors off at the end of every block level transfer, which of course is woefully non-performant since file transactions are composed of many block transfers.
    Any thoughts on the proper way to handle that?
    PS does anyone have any IMD images of an SCP 86-DOS double density 8" disk? I have single density FM ones but nothing MFM.
    would hooking INT 08H at the time of driver initialization with a handler be an appropriate way to time the motor shutdown?
    bear in mind this is my first foray into DOS programming of any kind so this is probably obvious to others, but I'm just not sure if this is the "right way" to do it
