Results 1 to 10 of 13
Thread: command-line tool that gives info about what's in a .scp (SuperCard Pro) file?
    Aug 2009
    Oslo, Norway
    1,343
    3
    Default command-line tool that gives info about what's in a .scp (SuperCard Pro) file?
    Yesterday, I put together a BluePill with Greaseweazle firmware on it, hooked it up to a 3.5 inch floppy for testing, and started trying out the gw software. Which records data to .scp files, and then you need another tool to change that into something more useful (all in all, an acceptable solution).
    However, I find that I would like to have a tool that can provide info about a .scp file. The format is documented: http://www.cbmstuff.com/downloads/sc...mage_specs.txt
    Before I start on creating my own, has anybody already made one? Preferably command line, in Python or something portable that works "everywhere'".
    Torfinn
    Mar 2013
    Chaffee, MO
    1,445
    Torfinn,
    I'm about 2 days behind you. I just received my parts to assemble the Blue Pill to the Version 1
    Adapter board yesterday. What version GW you running .6, .7 or .8?
    For Software check out the HxC Software: http://hxc2001.free.fr/floppy_drive_....html#download
    and file "HxCFloppyEmulator software v2.2.2.1"
    It will allow you to load the .SCP file and export it to various formats. Also view the Image.
    I built it for Debian Linux (64 bit). It works good.
    Also the SAMDisk Software by Simon Owen can do a few different formats.
    https://simonowen.com/samdisk/
    https://simonowen.com/samdisk/formats/
    Imports .SCP and can export .RAW and .IMD etc.
    Do you visit the Facebook GW Group?
    Larry
    Aug 2009
    Oslo, Norway
    1,343
    3
    Currently I'm using gw 0.7.
    Hmm, does the HxC software download include sources? Or did you get sources from SF.net?
    Facebook - no, I don't do Facebook. Ever.
    Torfinn
    Aug 2009
    Oslo, Norway
    1,343
    3
    Quote Originally Posted by tingo View Post
    Well that was easy. I checked out the HxC sources from SF.net and built it under Debian. Both command line and gui client starts. I haven't got any images here, so I can't test more.
    Torfinn
    Mar 2013
    Chaffee, MO
    1,445
    Torfinn,
    You will need to checkout the Source from Subversion (SVN). Here is a list of the Terminal
    commands I used. (It used to be a bit harder to build, because the source for fltk-1.3.5-source.tar.gz
    needed to be copied to the correct subdirectory. Now, it's all extracted and copied by the makefile.)
    Find the Current Kernel Info:
    $uname -r
    4.9.0-11-amd64
    (Debian has now renamed package svn to subversion)
    $sudo apt-get install build-essential linux-headers-$(uname -r)
    $sudo apt-get install libncurses5-dev libx11-dev subversion libxft-dev
    $which svn
    /usr/bin/svn
    $mkdir -p ~/Downloads/HxC/
    $cd ~/Downloads/HxC/
    Download fltk-1.3.5-source.tar.gz
    $cp ~/Downloads/fltk-1.3.5-source.tar.gz /home/larry/Downloads/HxC/
    Checkout Source Revision 1904:
    $svn checkout svn://svn.code.sf.net/p/hxcfloppyemu/code/ hxcfloppyemu-code
    Checked out revision 1904.
    $cd ~/Downloads/HxC/hxcfloppyemu-code-r1904/HxCFloppyEmulator/build
    $make
    Fix errors then:
    $make clean
    $make
    I then create a Launcher to execute the software.
    Larry
    Aug 2009
    Oslo, Norway
    1,343
    3
    Default hxcfe - works, but isn't perfect
    Ok, the hxcfe command line tool works, but it complains about the SCP images (which I have made straight from the Greaseweazle). Example:
    $ ./hxcfe -finput:/home/tingo/work/greaseweazle/Tingo_3_amiga.scp -infos
    HxC Floppy Emulator : Floppy image file converter v2.0.3.1
    Copyright (C) 2006-2019 Jean-Francois DEL NERO
    This program comes with ABSOLUTELY NO WARRANTY
    This is free software, and you are welcome to redistribute it
    under certain conditions;
    libhxcfe version : 2.10.4.1
    Input file : /home/tingo/work/greaseweazle/Tingo_3_amiga.scp
    -                        File informations                                -
    File: /home/tingo/work/greaseweazle/Tingo_3_amiga.scp
    Checking /home/tingo/work/greaseweazle/Tingo_3_amiga.scp
    File loader found : SCP_FLUX_STREAM (SCP Stream Loader)
    Loading /home/tingo/work/greaseweazle/Tingo_3_amiga.scp
    file loader found!
    Can't open /home/tingo/work/greaseweazle/config.script !
    Loading SCP file...
    Version : 0x00
    Disk Type : 0x80
    Start track : 0
    End track : 163
    Number of revolution(s) : 3
    Flags : 0x01
    File Checksum : 0xBE3E82A4
    Bit Cell width : 0
    Number of heads : 0
    Resolution factor : 0
    Invalid rpm or tracklen (15288 RPM, 749)...
    Invalid rpm or tracklen (4608 RPM, 750)...
    track file successfully loaded and encoded!
    File type : SCP_FLUX_STREAM - SCP Stream Loader
    Floppy interface mode : GENERIC_SHUGART_DD_FLOPPYMODE - Shugart Interface
    Number of Track : 82
    Number of Side : 2
    Total Size : 901120 Bytes, Number of sectors : 1760
    Stopping HxCFloppyEmulator...
    Torfinn
    Aug 2009
    Oslo, Norway
    1,343
    3
    good thing: '-list' works on .scp images
    tingo@kg-bsbox:~/work/greaseweazle/hxc/hxcfloppyemu-code/HxCFloppyEmulator/build$ ./hxcfe -finput:/home/tingo/work/greaseweazle/Tingo_3_amiga.scp -list
    -                        File image browser                               -
    file loader found!
    Loading SCP file...
    Version : 0x00
    Disk Type : 0x80
    Start track : 0
    End track : 163
    Flags : 0x01
    Bit Cell width : 0
    Number of heads : 0
    Number of Side : 2
    ------- Disk Tree --------
    hxcfe_readSectorData : ERROR -> Sector not found ! track 0, side 1, sector 1,Sector size:512,Type:0
    hxcfe_readSectorData : ERROR -> Sector not found ! track 0, side 0, sector 1,Sector size:512,Type:0
    hxcfe_readSectorData : ERROR -> Sector not found ! track 0, side 0, sector 1,Sector size:1024,Type:0
    hxcfe_readSectorData : ERROR -> Sector not found ! track 40, side 0, sector 11,Sector size:512,Type:1
    hxcfe_readSectorData : ERROR -> Sector not found ! track 80, side 0, sector 10,Sector size:512,Type:1
    AdfLib Warning: adfReadBootBlock : incorrect checksum
     DICE206B.LZH <409304>
     TURBOTITLE.LZH <96412>
     AREXXTUTOR.LZH <161381>
     EZASM.LZH <32023>
     LesMeg.txt <394>
     SYSIN236.LZH <34358>
    Torfinn
    Mar 2013
    Chaffee, MO
    1,445
    Torfinn,
    I tried the same command on a KAYPROII_IMD.scp file that my Supercard Pro Created.
    I copied the KAYPRO_IMD.scp to the build directory.
    $ cd ~/Downloads/HxC/hxcfloppyemu-code-r1904/HxCFloppyEmulator/build
    $ ./hxcfe -finput:KAYPRO1_IMD.scp -infos
    libhxcfe version : 2.10.2.2
    Input file : KAYPRO1_IMD.scp
    File: KAYPRO1_IMD.scp
    Checking KAYPRO1_IMD.scp
    Loading KAYPRO1_IMD.scp
    file loader found!
    Can't open config.script !
    Loading SCP file...
    Version : 0x09
    Disk Type : 0x14
    Start track : 0
    End track : 39
    Flags : 0x01
    File Checksum : 0x325583B0
    Bit Cell width : 0
    Number of heads : 1
    Number of Track : 40
    Number of Side : 1
    Total Size : 204800 Bytes, Number of sectors : 400
    $./hxcfe -finput:KAYPRO1_IMD.scp -list
    file loader found!
    Loading SCP file...
    Version : 0x09
    Disk Type : 0x14
    Start track : 0
    End track : 39
    Flags : 0x01
    Bit Cell width : 0
    Number of heads : 1
    Number of Side : 1
    hxcfe_readSectorData : ERROR -> Sector not found ! track 0, side 0, sector 10,Sector size:512,Type:0
    So, I'm seeing the same type errors.
    I did get two of the GreaseWeazles completed and the Firmware loaded for Ver 0.7. Now I'm ready to
    test with some assorted Floppy's.
    If you execute hxcfloppyemulator it should work properly.
    $ ./hxcfloppyemulator
    Then load your .SCP image and see what it looks like.
    Thanks.
    Larry
    Mar 2013
    Chaffee, MO
    1,445
    I'll have to post these errors on their forum so Jeff can have a look. Hopefully, he can get the
    problem solved quickly. Plus I need to download the latest subversion file and update my software.
    Larry
    You can also use Keir's Disk Utilities: https://github.com/keirf/Disk-Utilities
    The disk-analyser will push out info on what's in the SCP if you use it to do a conversion (e.g. into another scp, or sector format or whatever).
    d.
