Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Sparcstation IPC Cycle 5-ip CPU Upgrade possible?
    Here is a pic of the motherboard: IMG_0011.jpg
    4,764
    Nice! I like how they used both 30 and 72 pin SIMMs, so you could reuse what you had before the upgrade.
    Yes, although for some reason I can't get it to boot with only the 72pin simms installed.
    Someone uploaded the manual here:
    https://archive.org/details/bitsaver...665081/page/n1
    In general it seems pretty picky about RAM. FPM only and I had to match all the timings to get it to work reliably.
    Quote Originally Posted by Brian Archer View Post
    You linked the manual, so you might already know. But just in case: there's a jumper on the mainboard to control which type of memory is bank 0. If its set to FPM, it won't work with just the 72pin SIMMs. A set of DIP switches controls memory speed (relative to CPU speed), but I haven't played with it.
    And here's a photo of my mainboard and close-up of the CPU area. Taken with my phone, so not the best quality. If there's an interest I can take better photos with proper lighting and camera.
    Quote Originally Posted by mdx View Post
    Ok, thatís actually really cool. Your motherboard is the same as mine and you have what I think is a turbosparc carrier card. That should also work in a sparcstation 5. You could install a microsparc and run nextstep if you ever wanted provided we figure out how the cpu is clocked. If you feel comfortable it would be great to get a pic with the cpu removed.
    I tried to find docs/info on how to remove/install the TurboSparc carrier card but without success so far. Is there a tool / trick to removing the carrier card? I'd be interested in this too, but at this point I'm too worried I'd break something... BTW, the module is a different shape/size than the one for SS5s, so I assume it wouldn't fit (though I didn't actually compare dimensions exactly.)
