Results 1 to 9 of 9
Thread: S3 Virge Video Card- Extra RAM installed in card causes warped picture
    San Antonio, TX
    266
    Default S3 Virge Video Card- Extra RAM installed in card causes warped picture
    I've been trying to figure out something that doesn't make sense.
    On my ExpertColor S3 Virge, there are slots for extra video RAM, and one set of 3 solder vias to switch between 2 memory settings with a jumper (JP4):
    The thing is, I modified my card to use the extra memory (inserted pins in JP4), but the image does not show up properly (There are alternating light and dark bands when the jumper is swapped, but with proper hues). Is there something else missing, or is it the way it was manufactured?
    EDIT: Before you ask me about the quality of the memory, yes, I made sure it was good. I actually had a problem beforehand where the image looked significantly worse because of bad VRAM.
    Sep 2008
    SE MI
    4,503
    6
    Quote Originally Posted by T-Squared View Post
    Ensure that the chips are properly oriented and do you need drivers? You didn't mention your system and OS.
    San Antonio, TX
    266
    Sorry about that. Yes, I did check that they are oriented properly. The dot on the chip does go to the angled-off corner of the socket.
    The operating system or drivers don't exactly matter, as it shows up in any video mode already capable through the card without the drivers. (It is Windows 98SE, though.)
    Sep 2008
    SE MI
    4,503
    6
    You may want to head over to VOGONS as they have quite a bit on the Virge.
    Are you sure that's what JP4 does? I've never seen a video card with memory sockets that required soldering to upgrade.
    San Antonio, TX
    266
    Oh. Maybe I was wrong. JP3 was unpopulated, and seemed to reveal the memory. I'm not sure what pins 1+2 on JP4 did when jumpered.
    5,941
    44
    Are you positive you are using good VRAM/VRAM rated for the correct speed?
    Banding usually indicated at least one chip was failing.
    = Excellent space heater
    On the S3 cards I have worked with, you just installed extra RAM. No jumpers needed to be changed.
    I have similar card but later revision I think in win95 pc. I don't think i moved jumpers either.
