Results 1 to 3 of 3
Thread: DLV11J Line Driver
    Apr 2017
    Switzerland
    275
    Default DLV11J Line Driver
    On my Plessey DLV11J the line drivers ICs some UA9636 get rather hot as well as the DS0026 which is used to generate -12V are getting rather hot when I touch them. Is this normal?
    I dont have the PLESSY DLV11-J but I do have the DEC DLV11-j. the DS0026 and UA9636 do not get hot. Only slight warming after hours of operation. The excessive heat is usually a symptom of the drivers being abused and drawing excessive current. The good news is both parts are still available (or exact replacement) if you still have -12V the DS0026 is probably OK.
    Do the outputs work?
    Apr 2017
    Switzerland
    275
    Thanks, I suppose the DLV11J brand is not important, as long as these are the same ICs they are probably used the same way. Yes all lines are working. But I will keep an eye on them and probably get some spare before they are no longer available. Just in case.
