Results 1 to 10 of 16
Thread: How to have autoexec/config sys menus on on Caldera OPENDOS 7/DRDOS
    Jun 2013
    Montevideo, Uruguay
    433
    Default How to have autoexec/config sys menus on on Caldera OPENDOS 7/DRDOS
    Hi, currently quite familiar on how to do option menus on msdos but for some reason i can't get it to work on opendos.
    The syntax for the menus is different than on msdos.
    Got this example from here https://nscsysop.hypermart.net/multiboot.html
    Do this on my config sys example:
    echo=1. Server
    echo=2. DR-DOS
    echo=3. XCopy all files on C: to D:
    switch server, drdos, xcpy
    exit
    :server
    set config=server
    Files=60
    Buffers=60
    return
    :drdos
    set config=drdos
    Files=60
    Buffers=60
    Device=c:\OAKCDROMDRV.SYS /D:CD001
    return
    cpy
    set config=xcpy
    Files=60
    Buffers=60
    return
    Then on autoexec.bat
    IF "%config%"=="server" goto NOVELL
    IF "%config%"=="dos" goto DOS
    IF "%config%"=="xcpy" goto XCPY
    OS
    nwcdex.exe /d:CD001
    goto DONE
    :XCPY
    cls
    @echo Copying all files on C: to D:
    xcopy c:\*.* d: /h /r /f /v /e /s
    goto DONE
    :NOVELL
    cd c:\nwserver
    server -nl
    ONE
    When i reboot the menu options show fine i can choose using the keys 1 2 3.
    Then the selection part from config.sys will work the menu will jump to the correct :tag in config.sys and then go to autoexec.bat
    But then on autoexec.bat it will parse the complete file ignoring my "goto DONE" statments and the "IF" section will run every command in the file from top to bottom.
    Its hard to find good references for drdos most about menus on the web are about msdos.
    Someone have experience doing menus on drdos ?, or know a better wat to get menus on DOS in place of the build in commands ?
    Apr 2010
    Albany, OR USA
    904
    Try removing the "s around the %config% variables. I'm thinking they (the quotes) are forcing them to be treated as a string instead of a variable. Leave the "s around the words to the right of the == since these are strings.
    If you use the [CODE] tag (#) it should take care of everything.
    Apr 2010
    Albany, OR USA
    904
    Another potential issue is that all of your labels are upper case. The examples I found in the DR-DOS 6 User Guide show labels in batch files in lower case only. However, the manual does not specify if they MUST be lower case. Try changing the labels to lower case. Don't forget to change them in the GOTO statements as well. Also, the GOTO statements are upper case in the guide examples. Click on the tiny picture below to see an example from the manual.
    33,403
    Don't know what the differences are between DRDOS 7 and my DRDOS 6, but the section on configuration files and statements is pretty extensive in the 660-odd page user manual (when products were packed with real manuals and not just empty boxes with a CD inside).
    I'm guessing that you're confusing the batch file command syntax with the configuration command syntax. I believe that they're different.
    New Zealand
    4,100
    4
    DRDos manuals in pdf for,mat are available.
    Jun 2013
    Montevideo, Uruguay
    433
    Quote Originally Posted by ibmapc View Post
    Thanks for the info tested this removing "" and also using lowercase but the IF statments on the autoexec file are completly ignored.
    Jun 2013
    Montevideo, Uruguay
    433
    code what ?
    4,570
    code what ?
    Click on the Advanced button which gives a larger toolbar. The "#" button will surround the text in a Code block. Basically the same as a quote block but designed for code.
    For example,
    Jun 2013
    Montevideo, Uruguay
    433
    checked dr dos manual but i don't see anything about menus for config sys maybe will be best for me to delete dr.dos and just use ms dos.
