Results 1 to 10 of 14
Thread: My PS/2 Model 25-286 is actually a 486? What?
    Default My PS/2 Model 25-286 is actually a 486? What?
    So first off, sorry if this particular machine doesn't belong in this section, but I really didn't know how to classify this machine in it's current state
    So, right to it then...
    As you might be able to see, that isn't the machine's original system board, it's a reply board with a socketed Intel 486 DX4, two 72-Pin SIMM slots and an on-board IDE and SCSI(?) controller. This also isn't some hack-job by someone wanting to make their 25-286 a 486 at any cost, it's actually a board that was purpose built to go into this system as it utilizes all of the systems original connectors, riser and even the proprietary IBM floppy, so obviously Reply manufactured and sold this as an upgrade at some point. Unfortunately, my scouring of the Internet hasn't turned up much on this machine, though the markings on the board identify this as a "Reply 050087 02 Rev. A2"
    Anyways, this is one cool little board though I am wondering, does this take Industry Standard SIMMs? Or the proprietary, unobtainable IBM ones?
    1,790
    If the machine doesn't have IBM branded SIMMs, they're probably normal types.
    http://john.ccac.rwth-aachen.de:8000/misc/ps2cache/
    You can try some different SIMMs, the worst that will happen is the machine won't boot. It's not like IBM did something really dumb like swap VCC and GND pins around.
    What a find! Always wanted one of those.
    Compaq - “It simply works better”
    "Reply" PS/2s are the PS/2 Holy Grail.
    PS/2s--M-30,M-40SX,M-50Z, M-57, M-70, M-77, M-80
    what a find to stumble into
    Quote Originally Posted by Hal9000 View Post
    Definitely. Wish I could find the Reply board for the Model 80!
    Feb 2017
    Guildford, U.K.
    294
    Louis's site is our current actively managed repository of all matters PS/2-related:
    http://ps-2.kev009.com/ohlandl/
    Scroll down until you find the Reply section.
    They are in fact industry standard (thank god). It had a single 16Mb stick shoved in it.
    Ah-ha! Thank you!
    Quote Originally Posted by compaqportableplus View Post
    Dang, I had no idea these were that rare.
    By the way, does anyone know what the cable I need to stick the original ESDI drive back in this machine looks like? I refuse to use a common lemming IDE drive with my exceptional PS/2 system
