Results 11 to 20 of 41
Thread: IBM Tandon TM100-2A Floppy Drive Format ?
    Mar 2013
    Chaffee, MO
    1,347
    What happens if you use the /1 switch?
    FORMAT A: /F:180 /1
    Larry
    33,417
    Do a plain old single-sided FORMAT without the system parameter and look at the disk usage summary.
    My guess is that you probably have a number of bad clusters early on in the floppy.
    Hey guys, sorry for the delay. I finally had some time to try out all of your suggestions. Here are the results:
    Have you tried running the two operations independently?
    E.g.,
    FORMAT A: /F:180
    then,
    SYS C:
    This can sometimes work better than the other way.
    I think you meant to type SYS A: and not SYS C: as that would of copied the system files to the C: drive and not the floppy. Format A: /F:180 went well but after typing SYS A: I get error "Could not copy COMMAND.COM to target disk"
    [QUOTE=ldkraemer;602980]What happens if you use the /1 switch?
    FORMAT A: /F:180 /1
    I get Parameter not compatible. Format terminated. (FORMAT A: /F:180 /1)
    Please see attached image of a FORMAT A: command with a brand new 360K floppy disk.
    Dec 2005
    Toronto ON Canada
    7,257
    Quote Originally Posted by MaCJaX View Post
    On a single-sided drive? Remarkable!
    And that's only one side of the story.
    DOS 6.22 is wasteful when doing format /s. It always tries to stick drvspace.bin on there, just in case you’ve compressed your HDD. If you do a dir /a you’ll see it. I’m not sure if there is an easy way to keep it from doing it. I haven’t tried yet. But I will now.
    Edit: ok I figured out how to do it. If drvspace.bin exists at c:\ or c:\dos, or probably anywhere in the path, then delete it (or rename it, etc). Then when you format /s or sys the disk it will work.
    33,417
    DOS 6.22? Try FORMAT A: /F:180 /U
    Otherwise, DOS will try to use any format already existing.
    The issue they’re having with 6.22 is that the system files won’t fit when he formats a single sided floppy. It’s because of the mostly useless drvspace.bin
    33,417
    Are you certain? One can always copy over MSDOS.SYS and IO.SYS and COMMAND.COM manually.
    I’m certain, I tried it. And then I posted the work around showing that it works after renaming drvspace.bin
