Results 1 to 4 of 4
Thread: Need information on this motherboard please
    Jan 2020
    North York ontario
    5
    Default Need information on this motherboard please
    Can anyone tell me about this Mobo and what power cord i need? Thanks!
    33,350
    Power cord? Looks like a standard AT (not ATX) power supply should work.
    You'll need to do something about that NiCd barrel battery--the corrosion is visible.
    Sep 2008
    SE MI
    4,409
    6
    What Chuck said. Look for an AT type power supply which has 2 rails (leads) that are marked 'P8' & 'P9'. These leads snap in to connecter which is between your RAM sockets and the DIN plug for your keyboard. Very important: When you attach the P8 & P9 leads, make sure the the BLACK ground wire are adjacent to one and another. In other words, the black grounds should appear to be in the MIDDLE. Also, do you have a friend close by that has some computer savvy to help with the basics? Good luck.
    https://www.computerhope.com/jargon/p/p8.htm
    as mentioned: get that battery off there ASAP RFN
    cut it off with a pair of dykes if you have to, that caustic electrolyte that's leaking out will devour the traces on that board
    clean the area around where the battery was with some white vinegar afterwards to neutralize the basic battery fluid
    also: cool board, is that a socket 3/4 combo board??
