Page 9 of 13 FirstFirst ... 5678910111213 LastLast
Results 81 to 90 of 121
Thread: Why isn't there a DOS forum ?
  1. #81
    Try running dir /s "*xyz*" on MS-DOS.
    How well does MSDOS handle symbolic links?
    How well does CP/M handle subdirectories ? Why ask such a question when you already know the OS is too old to support that feature ?
    You have to understand that the fundamental idea of Linux/Unix is that everything is a file that can be piped through another command...and so on. If you understand this and your chosen shell operations, you can do some great things.
    Again I do not like Linux/Unix. Stop trying to sell me on it. If you like it then that's fine, I don't and it will be a cold day on Venus before I ever use it as my primary OS on any PC I own.
  2. #82
    "junction"? Do you mean "join"?
    no, in NTFS, junction. A symbolic link to a directory is called a junction in NTFS land.
    mklink (built into cmd on win vista + up) or junction.exe
    https://en.wikipedia.org/wiki/NTFS_links
  3. #83
    Aug 2006
    Chicagoland, Illinois, USA
    6,345
    Quote Originally Posted by pcdosretro View Post
    Then maybe you shouldn't make claims like "there too many things which are doable in the DOS/Windows shells that are a pain or undoable in Unix/Linux shells"?
    I can't think of a single thing possible in cmd.exe or powershell that isn't possible in a unix shell, so if you know of a concrete example, I'd be curious to hear it.
    Offering a bounty for:
  4. #84
    33,661
    18
    Quote Originally Posted by BloodyCactus View Post
    Weren't we talking about MSDOS? That's not NT.
    FWIW, I've always wondered if there was a way to prevent MSDOS from executing a command in the currently logged directory. I suspect there probably is, but haven't been curious enough to research it.
    And also, for what it's worth, I've been using *nix on and off since before there was an MSDOS. I use whatever the job requires, so it pays to be fluent in all of them. Yesterday I had work that required MacOS 9.2...
    After your first dozen or so operating systems, you get the general idea of how things work pretty quickly. There's a huge difference between an operating system and a shell/UI, also.
  5. #85
    Sure... type the command with it's PATH name, outside of the current directory.
    But that's probably not what you were striving for.
    PM me if you're looking for 3½" or 5¼" floppy disks. EMail “ ” For everything else, Take Another Step
  6. #86
    Dec 2010
    Seattle, WA
    1,946
    Does he want to have just one argument, or was he thinking of taking a course?
  7. #87
    33,661
    18
    No--I wanted to avoid the situation where there's an executable file called, say, "MYPROG.EXE" in both the search path and the locally logged-on directory. You enter the command "MYPROG" and you get the local copy by default. *nix omits the local directory from command searches by default.
  8. #88
    So does calling it with its PATH name.
  9. #89
    This thread has drifted quite a bit from it's original topic ...
    Time for a new thread maybe? Or just perhaps, agree to disagree?
  10. #90
    I don't have a ton of nix experience, but I find this annoying to have to type ./myprog for example. I get the idea of why they did it this way, but I'm just too wed to my MS-DOS ways to be content with it.
