Results 1 to 2 of 2
Thread: WTB/T 10base2 ethernet equipment
    Default WTB/T 10base2 ethernet equipment
    After spending over 2 months trying to get my retro machines connected to my file server via 10baseT, and running into every possible issue, I've decided that I'm going to set up a 10base2 network.
    No stupid hubs to deal with, I just connect the machines and go.
    If anyone's got any 10base2 stuff they want to get rid of (ethernet cards, coax cables, T-connectors, Terminators) let me know.
    I've deleted two responses to this thread that should have been sent as private messages.
    If you are responding to a specific request, use the private message system. We're trying to keep the signal-to-noise ratio high.
