Page 6 of 10 FirstFirst ... 2345678910 LastLast
Results 51 to 60 of 97
Thread: Worst x86 CPUs over the years
  1. #51
    May 2011
    Outer Mongolia
    1,940
    ... In any case, there's no way the C3 does any sort of dynamic, optimizing translation like the Transmeta did, unless there's benchmarks I don't know about it that show it. The Transmeta CPUs were sort of famous/infamous for running code at unpredictable speeds, at least until they'd filled up their secret RAM space with optimized translations.
  2. #52
    33,446
    18
    Look up the thread a few postings. I believe I posted something to this effect.
  3. Default
    I'd always understood the C3 to be a VLIW core design. Is this not true?
    The C3 is internally RISC, its a modified winchip on higher clock speeds and different socket/wiring.
    But, every processor nowdays are doing x86 to risc translation inside, so in this aspect, they are similar to each other. But no one uses VLIW any more, except the russian Elbrus.
  4. #54
    May 2011
    Outer Mongolia
    1,940
    About the AIS? Have you actually found any compilers or public command references for it? I dug around and it seems like Via hasn’t done much more than publicly acknowledge it exists and that it’s what “God mode” is really tickling.
  5. #55
    33,446
    18
    ALTINST is implemented in NASM, but that's as far as it goes. Here's the link to the original Domas paper. Not terribly helpful if you're looking for specific instruction descriptions, however.
  6. #56
    May 2011
    Outer Mongolia
    1,940
    As an aside, this thread about the C3 just hit the magic point where it’s motivated me to dig out the fanless Eden ITX box from the junk shelf to play with. I thought of the thing as an utter waste of time with it slogging through Linux back in the day, time to try it under DOS. (Assuming it still works a decade later...)
    (Edit: Interesting; it was acting dead as a doornail, just a black screen with no beeping, but after I randomly tried moving the little red jumper next to the CMOS battery to the alternate position and back again it's working fine. Maybe I should download the manual and see what that jumper actually does now...)
  7. Default
    btw my c3 board is only accepting one specific 512 mbyte ecc ddr ram module. it refuses to boot with any other ram.
  8. #58
    May 2011
    Outer Mongolia
    1,940
    I hope my particular board supports the DOS soundblaster driver that’s apparently floating around for older EPIA platforms. If I can make that and mTCP work I may suddenly like it. Having a Tandy 1000 as my only other DOS machine should set my performance expectations sufficiently low.
  9. Default
    I dont think you could expect good results, Eudimorphodon. The WinChip (C3) was optimized for 32 bit and for office programs. For good DOS compatibility, you need some real ISA sound card and some PCI or first generation AGP card.
  10. #60
    Oct 2016
    Dutchess County, New York, USA
    78
    I'll vote for the Cyrix and VIA cpu's.
    As an inverse of worst CPU's I'd put in a vote for most overlooked - the AMD K6-II+ and 3+ CPU's that weren't sold to the general public IIRC. Very nice CPU's for their time.
    Crazy old guy with a basement full of Pentium 1 laptops and parts
