Results 1 to 10 of 12
Thread: IBM XT 5160 POSTs but won't boot
    Default IBM XT 5160 POSTs but won't boot
    I've got an IBM XT 5160 which is having an issue booting.
    It was working perfectly one day but then the following day no longer worked without anything having been changed.
    It powers on and successfully completes the memory test, then does a seek on the floppy drive. It then goes to a blank screen with a flashing cursor where nothing further happens. It doesn't even attempt to read either the floppy drive or hard drive. Occasionally it will boot into BASIC, but most of the time it will sit on the blank screen forever.
    I've removed all expansion cards other than video and floppy controller. I've also replaced both the floppy controller and floppy drive with known working ones from my 5150. The DIP switches are all configured correctly. I've burnt a new copy of the BIOS onto a couple of EEPROMs and installed it in the motherboard. None of these things made any difference. It still had the exact same symptoms.
    I'm pretty confident that the problem is on the motherboard given that I've replaced everything else. What sort of things could cause this issue?
    have you ruled out issues with power supply?
    Is the hard drive spinning - maybe it will give a hint ?
    Did you try the burned bios eepproms on another motherboard just to make sure they are ok?
    The PSU is putting out good voltage levels so everything there is all good.
    I don't have another 5160 to test the BIOS on, but since it did run through the memory test I'm assuming that it's probably okay. I also tried the diagnostic ROM from this page:
    http://minuszerodegrees.net/supersof...mark%20ROM.htm
    The diagnostics ran correctly and all tests passed with flying colours. Still has the same boot problem when going back to the standard BIOS though.
    6,484
    Quote Originally Posted by seanneko View Post
    In case relevant for later, which motherboard: 64-256KB or 256-640KB ?
    In case relevant for later, which video card ?
    Well, except for video card and power supply.
    It is hard for me to believe that the power supply could cause the particular symptom.
    I do not think that you should rule out the video card just yet.
    At [here] is a breakdown of the 5160's power-on self test (POST).
    Your "seek on the floppy drive" will correspond to the 'DISKETTE ATTACHMENT TEST' action.
    It then goes to a blank screen with a flashing cursor ...
    Possibly a result of the 'CLEAR SCREEN' action.
    Before 'CLEAR SCREEN' is 'LOOP POST'. If you set switch 1 on motherboard switch block SW1 to the ON position, does the POST run in a loop ?
    If it does, that would suggest to me that your "It then goes to a blank screen" is a result of the 'CLEAR SCREEN' action.
    Looking at what follows the 'CLEAR SCREEN' action, and there is not much, the 'ENABLE NON MASKABLE INTERRUPTS' may be where things are going wrong. For diagnostic purposes, it is possible to stop that action by grounding a certain pin of a certain motherboard chip. Do you have the means to do that if we tell you which pin/chip ? If with the pin grounded, the motherboard does the 'DO BOOTSTRAP' action, then we have narrowed the problem cause to a non-maskable interrupt related one.
    So, four questions asked.
    64-256KB motherboard with 256KB installed.
    It currently has an IBM CGA card. I forgot to mention in my first post, but I have swapped it out for both a clone CGA card as well as a Hercules card. The fault still remained regardless of which video card was installed.
    I just gave that a shot. Correct, it runs the POST in a loop now when switch 1 is turned on.
    I'm reasonably handy with a soldering iron so I should be able to ground the pin. Which one should I be looking at?
    Thanks for the help.
    it is also "possible" that it is still a ram issue. on my Tandy 1000TL, the system woulkd actually pass its POST, RAM check wouldn't give any memory errors, but the machine was flaky and unreliable. Crashing seemingly at random.
    I ended up running Check-IT (i was lucky the system would still boot) and only running check-it did it show me i had LOTS of memory errors. ended up replacing an entire bank of 41256 ram ICS and finally the system behaved normally.
    all I'm getting at, just because the POST thinks the ram is okay, it 'might' not be. The ram chips in these old machines are EXTREMELY cranky in their old age.
    6,484
    What I use is like what is shown at [here], except that there is a hook at each end. One hook onto the ground pin of the IC, and the other hook onto the target pin.
    Refer to the diagram at [here], in particular, the U87 AND gate at the right. The 'ENABLE NON MASKABLE INTERRUPTS' action of the POST takes the bottom input leg of U87 HIGH, enabling the output of the U72 OR gate through to the NMI line of the CPU. So one of the pins that can be tied to ground to achieve the test is the bottom input leg of U87, and that pin is pin 9.
    I tried grounding pin 9 of U87, and... no change It still gets stuck on the same flashing cursor.
    I was curious if I could get it to boot into BASIC, so I pulled the floppy controller out and powered on. It of course gave me a 601 error, but after pressing F1 it successfully booted into BASIC. I can get it to repeat this over and over. Correct me if I'm wrong, but this means that it's completing POST but for some reason failing during the bootstrap.
    I then put back in the MFM controller but left the floppy controller out. When it attempts to perform the bootstrap the HDD LED lights up for a second (but the drive doesn't appear to make any seeking noises), then the LED goes out and it again sits on the flashing cursor screen forever. It doesn't enter BASIC.
    It seems like the problem is on the drive and/or controller, but as I said I've swapped both out with known good ones, so I don't think that's the case.
    have you tried to remove hard drive controller and boot with floppy only ?
    does it still behave the same ?
    edit:
    ah yes, in your first post you say that you just did that.
    6,484
    I draw the same conclusion.
    Note that Cassette BASIC is not some kind of failure fallback for all booting code. For example, when a DOS boot floppy is being booted from, if the boot code finds COMMAND.COM missing, execution is not then passed to Cassette BASIC.
    Some things that are common between the floppy 'system' and the hard drive 'system', and are not required for the POST, are:
    * +12V. An unstable +12V ?
    * ISA bus
    The hardware tests done by the POST, and by the Supersoft/Landmark diagnostics are basic. The idea is that, if needed, you execute 'proper' diagnostics after booting to DOS.
    As pinkdonut666 suggested, a possibility is a RAM related problem (e.g. RAM addressing). During the POST, RAM usage is minimal. The interrupt vectors are created, and the BIOS Data Area (BDA) written to. All that is in the very low RAM addresses. When DOS starts to boot and load, RAM is starting to be used seriously.
