Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Linux for M68K
    Aug 2017
    New Mexico, USA
    113
    Default Linux for M68K
    I've developed a 68030 homebrew. I'm interested in porting Linux for M68K. Can anyone provide current status of Linux-M68K and whom to contact? Thanks
    Bill
    33,363
    Aug 2017
    New Mexico, USA
    113
    Thanks, I ran across that page before and was discouraged because it mentioned Debian 2.0 and 4.0 which were over a dozen years ago. I took another look and found an archive on that page with more recent materials.
    Bill
    Sep 2006
    Silicon Valley
    2,147
    I think your new board is pretty neat. Do you have enough parts to make full or assembled kits?
    I still have two of the 68030 boards with ISA slots that Ingo Cyliax made at Indiana University.
    http://marc.retronik.fr/motorola/68K..._1997_18p].pdf
    There is the start of a simulation for it in MAME
    A daughterboard for your SBC with 8-bit ISA slots might be a fun thing to build, or adding SPI to use a wiznet module.
    A modern Linux has bloated in the 2000's to not even being able to run on a Sun SPARC.
    You would probably have better luck with netBSD
    Yeah, I'd definitely look to the BSDs if you want any kind of semi-current support for discontinued 32-bit architectures. These days I'm surprised the major Linux distros still have x86 support.
    Aug 2017
    New Mexico, USA
    113
    Etchedpixels also mentioned NetBSD. Sadly I'm not well versed in NetBSD nor Linux. I'm looking for guidance in hardware requirements--memory size, disk size, FPU or not. The actual porting of NetBSD or Linux is likely beyond me. I was successful in porting CP/M68K to it, however.
    https://www.retrobrewcomputers.org/d...asmo:cb030spec
    I guess you've figured out where to find my design. My intention is to offer a partially assembled board with SMT devices assembled and CPLD programmed for $15-$20 so people can provide their own 68030, SIMM72, EPROM, I/O to build their own 68030 SBC. I can put together kit and it is likely around $50. I hope to make it reasonably priced so to attract the software talents to port modern OS to it.
    The SBC does have an 8-bit I/O expansion slot for additional serial ports and possibly Ethernet board.
    Bill
    PS, link to retrobrewcomputers.org seem to be truncated so the link is broken. The name of the 68030 homebrew is CB030. This is the link, spelled out:
    www-dot-retrobrewcomputers-dot-org/doku-dot-php?id=builderpages:plasmo:cb030spec
    Kernel version 2.6.27-rotary-wombat-m68k-apple-lc475-68060
    - compiled by root@queen-vittoria
    - compiled with gcc version 3.4.5
    - compiled on 19 Tue Jan 2009
    Detected Macintosh model: LC475
     Bootinfo data:
     Video: addr 0xf9001000 row 0x400 depth 8 dimensions 640 x 480
     Videological 0xf0101000 phys. 0x51901000, SCC at 0x50f0c020
     Boottime: 0xe71c3e2a GMTBias: 0x0
     Machine ID: 90 CPUid: 0x2 memory size: 0x24
    VIA1 at 50f00000 is a 6522 or clone
    VIA2 at 50f02000 is a 6522 or clone
    On node 0 totalpages: 9216
    free_area_init_node: node 0, pgdat 00207b9c, node_mem_map 00257000
      DMA zone: 9135 pages, LIFO batch:1
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 9135
    Kernel command line: root=/dev/sda7 init=/sbin/initmini
    mac_init_IRQ(): Setting things up …
    - Killing onboard sonic ethernet card ... <6>Done
    mac_init_IRQ(): Done!
    CPU HACK: 68060 support pack armed
    PID hash table entries: 256 (order: 8, 1024 bytes)
    mac_enable_irq irq=14, irq_src=1 <6> via_irq_enable <6>
    Console: colour dummy device 80x25
    console [tty0] enabled
    Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
    Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
    Memory: 34072k/34092k available (1544k kernel code, 1144k data, 84k init)
    SLUB: Genslabs=12, HWalign=16, Order=0-3, MinObjects=0, CPUs=1, Nodes=8
    Calibrating delay loop... 31.70 BogoMIPS
    Mount-cache hash table entries: 512
    net_namespace: 292 bytes
    NET: Registered protocol family 16
    NuBus: Scanning NuBus slots.
    Now probing slot E at feffffff
    Now probing slot E at fefffffe
    Slot E:
      Board resource:
        type: [cat 0x1 type 0x0 hw 0x0 sw 0x0]
        board id: 0x8
        vendor info:
        ID: TFL LAN INC.
        revision: REV 1.1
        part: E410 NuBus/E420 LC PDS,EtherNet Adapter
      Function 0x08:
        type: [cat 0x4 type 0x1 hw 0x11e sw 0x100]
        memory offset: 0x000d0000
        MAC address: 00:a0:4b:08:db:26
    SCSI subsystem initialized
    NET: Registered protocol family 2
    IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
    TCP established hash table entries: 2048 (order: 2, 16384 bytes)
    TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
    TCP: Hash tables configured (established 2048 bind 2048)
    TCP reno registered
    msgmni has been set to 66
    io scheduler noop registered
    io scheduler anticipatory registered
    io scheduler deadline registered
    io scheduler cfq registered (default)
    macfb: framebuffer at 0xf9001000, mapped to 0x02800000, size 480k
    macfb: mode is 640x480x8, linelength=1024
    macfb: scrolling: redraw
    Console: switching to colour frame buffer device 80x30
    fb0: DAFB frame buffer device
    r3964: Philips r3964 Driver $Revision: 1.10 $
    Ethernet Channel Bonding Driver: v3.3.0 (June 10, 2008)
    bonding: Warning: either miimon or arp_interval and arp_ip_target module parameters must be specified, otherwise bonding will not detect link failures! see bonding.txt for details.
    mac8390.c: v0.4 2001-05-15 David Huggins-Daines <dhd@debian.org> and others
    eth0: Memory length resource for slot E not found, probing
    eth0: EtherNet card in slot E (type apple)
    MAC 00:a0:4b:08:db:26 IRQ 61, 32 KB shared memory at 0xfeed0000,  32-bit access.
    tun: Universal TUN/TAP device driver, 1.6
    tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
    input: Macintosh mouse button emulation as /class/input/input0
    mac_enable_irq irq=10, irq_src=1 <6> via_irq_enable <6>
    Macintosh CUDA driver v0.5 for Unified ADB.
    adb: starting probe task …
    mac_esp: using PDMA for controller 0
    mac_enable_irq irq=19, irq_src=2 <6> (via:present) <6>
    esp: esp0, regs[50f10000:0] irq[19]
    esp: esp0 is a ESP236, 16 MHz (ccf=4), SCSI ID 7
    adb devices: [2]: 2 8
    ADB keyboard at 2, handler 1
    Detected ADB keyboard, type ANSI.
    input: ADB keyboard as /class/input/input1
    adb: finished probe task...
    scsi0 : esp
    osst :I: Tape driver with OnStream support version 0.99.4
    osst :I: $Id: osst.c,v 1.73 2005/01/01 21:13:34 wriede Exp $
    Driver 'osst' needs updating - please use bus_type methods
    scsi 0:0:0:0: Direct-Access     SEAGATE  ST32550N         8607 PQ: 0 ANSI: 2
     target0:0:0: Beginning Domain Validation
    Driver 'sd' needs updating - please use bus_type methods
    Driver 'sr' needs updating - please use bus_type methods
    SCSI Media Changer driver v0.25
    Driver 'ch' needs updating - please use bus_type methods
     target0:0:0: FAST-5 SCSI 3.3 MB/s ST (304 ns, offset 15)
     target0:0:0: Domain Validation skipping write tests
     target0:0:0: Ending Domain Validation
    mice: PS/2 mouse device common for all mice
    NET: Registered protocol family 26
    IPv4 over IPv4 tunneling driver
    sd 0:0:0:0: [sda] 4194995 512-byte hardware sectors (2148 MB)
    TCP bic registered
    TCP cubic registered
    TCP westwood registered
    TCP htcp registered
    NET: Registered protocol family 17
    NET: Registered protocol family 15
    802.1Q VLAN Support v1.8
    sd 0:0:0:0: [sda] Write Protect is off
    sd 0:0:0:0: [sda] Mode Sense: ab 00 10 08
    scsi: waiting for bus probes to complete ...
    sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, supports DPO and FUA
     sda: [mac] sda1 sda2 sda3 sda4 sda5 sda6 sda7
    sd 0:0:0:0: [sda] Attached SCSI disk
    sd 0:0:0:0: Attached scsi generic sg0 type 0
    kjournald starting.  Commit interval 5 seconds
    EXT3-fs: mounted filesystem with ordered data mode.
    VFS: Mounted root (ext3 filesystem) readonly.
    EXT3-fs warning: checktime reached, running e2fsck is recommended
    EXT3 FS on sda7, internal journal
    # mac-fdisk /dev/sda
    Codice: [Seleziona]
    /dev/sda
    Command (? for help): p
    Disk /dev/sda
            #  type name          length   base    ( size )  system
    /dev/sda1   map Apple             63 @ 1       ( 31.5k)  Partition map
    /dev/sda2  Dr43 Macintosh         32 @ 64      ( 16.0k)  Driver 4.3
    /dev/sda3   HFS MacOS           4096 @ 96      (  2.0M)  HFS
    /dev/sda4  ???? bootstrap       1600 @ 4192    (800.0k)  NewWorld bootblock
    /dev/sda5  unix boot           32768 @ 5792    ( 16.0M)  Unix native
    /dev/sda6  unix swap          409600 @ 38560   (200.0M)  Unix swap
    /dev/sda7  unix gentoo       3746835 @ 448160  (  1.8G)  Unix native
    Block size=512, Number of Blocks=4194995
    # gcc -v
    Target: m68k-unknown-linux-gnu
    Configured with: /var/tmp/portage/sys-devel/gcc-4.2.3/work/gcc-4.2.3/configure --prefix=/usr --bindir=/usr/m68k-unknown-linux-gnu/gcc-bin/4.2.3 --includedir=/usr/lib/gcc/m68k-unknown-linux-gnu/4.2.3/include --datadir=/usr/share/gcc-data/m68k-unknown-linux-gnu/4.2.3 --mandir=/usr/share/gcc-data/m68k-unknown-linux-gnu/4.2.3/man --infodir=/usr/share/gcc-data/m68k-unknown-linux-gnu/4.2.3/info --with-gxx-include-dir=/usr/lib/gcc/m68k-unknown-linux-gnu/4.2.3/include/g++-v4 --host=m68k-unknown-linux-gnu --build=m68k-unknown-linux-gnu --disable-altivec --disable-nls --with-system-zlib --disable-checking --disable-werror --enable-secureplt --disable-libunwind-exceptions --disable-multilib --disable-libmudflap --disable-libssp --disable-libgcj --enable-languages=c,c++,objc,obj-c++,treelang,fortran --enable-shared --enable-threads=posix --enable-__cxa_atexit --enable-clocale=gnu
    Thread model: posix
    gcc version 4.2.3 (Gentoo 4.2.3 p1.0)
    # cat /proc/cpuinfo
    CPU:      68060
    MMU:      68060
    FPU:      68060
    Clocking:   33 MHz
    Years ago I hacked an Apple LC475 to have a 68060 CPU on it. All the four ROMs were modified, and also the PLL, and I cooked a Gentoo Stage1,2,3,4 (it took five months).
    The result was interesting and exciting, but ... the console was practically definitively too slow.
    #include <stdio.h>
    int main()
       printf("hAllo world, i do muuuuuuuu again\n");
       return 0;
    # time gcc hAllo.c -o hAllo
    real   0m6.890s
    user   0m5.620s
    sys   0m1.260s
    Look how slow was compiling a simple "hAllo world" C program.
    # ./hAllo
    @Plasmo
    I will buy one board, but not for Linux. I'd like to develop a kind of embedded applications OS-less.
    NetBSD is the only unix/Linux that I'm aware of which is still under active development for M68k, and it would also run quite well within a single SIMM. I'm not sure how difficult it would be to port but I believe the reason why things like Amiga or Mac require a full project is because they aim to support a wide variety of hardware and a build for the CB030 would only need to support the one configuration. If you're able to start selling them as kits it would probably go quite a ways towards garnering some interest from people more familiar with that side of things (I know I have no way of building boards using SMT components).
    That being said, maybe the KISS-68030 ECB board project on retrobrew could provide a kick-start? There was a running version of linux (kernel 4.4.1 according to the video) built for it, although it's several years out of date and I can't find a download for it on the site. It may have been lost when they rolled over the site a while back, it's from about 3-4 years ago.
    Aug 2009
    Oslo, Norway
    1,296
    3
    It would be nice to have an M68k machine to run Linux, *BSD, and other os'es on.
    Last edited by tingo; January 25th, 2020 at 05:59 AM. Reason: fixed a spelling error
    Torfinn
