Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 51
Thread: Linux for M68K
  1. #41
    Aug 2017
    New Mexico, USA
    129
    My CB030 has reached some level of maturity. It is a homebrew 24MHz 68030 that works well with 16meg or 64 meg of DRAM, the compact flash interface is solid and I have CP/M68K ported and operating reliably. It is strictly a serial console interface without any video/graphic interface. It does not have a floating point coprocessor. I want to see if I can port NetBSD or FreeBSD to it. To double up the challenge, I'm not a Linux user, but am ready for a long journey. Please tell me where to start.
    Bill
    PS, CB030 homepage is under construction here:
    https://www.retrobrewcomputers.org/d...030:cb030_rev1
  2. #42
    NetBSD is a good fit for trying to do a port. You can build a 68k userland and kernel from source on a fast x86 machine using the native build.sh structure. NetBSD does run on 68k macs without an fpu. You can also run it on an emulated Amiga in Winuae. FreeBSD does not run on 68k and modern Debian (unsupported since 4.0) is pretty slow even on beefy Amigas.
  3. #43
    Aug 2017
    New Mexico, USA
    129
    I think your new board is pretty neat. Do you have enough parts to make full or assembled kits?
    I still have two of the 68030 boards with ISA slots that Ingo Cyliax made at Indiana University.
    http://marc.retronik.fr/motorola/68K..._1997_18p].pdf
    There is the start of a simulation for it in MAME
    A daughterboard for your SBC with 8-bit ISA slots might be a fun thing to build, or adding SPI to use a wiznet module.
    A modern Linux has bloated in the 2000's to not even being able to run on a Sun SPARC.
    You would probably have better luck with netBSD
    Hi Al,
    I sent you a PM regarding the CB030 that's currently auctioned on eBay.
    Bill
  4. #44
    Given that the CB030 looks like an interesting board, but my area is more software, does anybody have any pointers on how to bring NetBSD up on a 68030 Qemu? I thought it would be a good starter for getting NetBSD ported to the CB030 board.
    Thanks, Warren
  5. #45
    Aug 2017
    New Mexico, USA
    129
    Mike McDonald has ported Linux 4.9.156 to CB030. You can find the details here:
    https://www.retrobrewcomputers.org/d...:mikemac:cb030
    Bill
  6. #46
    Feb 2010
    Russia, St.Petersburg
    221
    Can anyone please suggesr a light opensource emultor to run relative modern m68k Linux (i.e. Debian) ?
    "Minimal system" is enought, not a full system emulator like HATARI, ARANYM or Snoebill.
    Somethinkg like MUSASHI emulation kernel plus serial plus IDE plus framebuffer wold be enought.
    AFAIK QEMU did not support full m68k emulation (userspace only) but I didn't try it for years...
  7. #47
    Sep 2006
    Silicon Valley
    2,268
    Quote Originally Posted by alecv View Post
    MAME has the pieces, but you'll have to put together your own driver.
    You also don't say which 68K, i'm assuming 68030
  8. #48
    I managed to get Debian 10.0 running on qemu-system-m68k by mostly following the instructions at https://wiki.qemu.org/Documentation/Platforms/m68k.
    Here are my full notes: https://gist.github.com/DoctorWkt/78...6bcdd35dd583ef
  9. #49
    Feb 2010
    221
    I’ve successfully built recent QEMU git (5.0.50) on MSYS2 under Windows10.
    It boots m68k Linux 4.16.0 (unofficial Debian 10 Sid).
    It emulates Quadra 800 with 68040 CPU (1Gb RAM and about 300MHz on my i3 machine)
  10. Default
    Is it something that I can run for e.g. on Amiga Vampire?
    Thanks for answer in advance
