Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Just got a "highly" modded Model I - questions
    Jan 2011
    Portland, Oregon
    696
    Default Just got a "highly" modded Model I - questions
    The Model I came with a nice EI (with doubler and two power supplies), two Aerocomp drives (as yet untested), and a nice quietly working 5 Meg HD (only two partiions, for some reason).
    The Mod I unit is a 26-1001D with a D motherboard. It works rather flakily (next step is to reseat all the chips) and the keyboard has TERRIBLE bounce (Custom TRS-80, page 99). It does have a lower case mod with descenders.
    Visually, the Mod I has a D9 male connector and two slider switches on the right side (pic 1) and tags on some keys for a strange-to-me program (pic 2, not shown, on the right side of the keyboard the "@" is tagged CONTROL and the "->" is marked Tab). In quick testing, I couldn't find any difference in operation with the switches put in any of the four possible combos. There is also a D9 connector mounted in the same position of the left side of the keyboard, but it is non-functional.
    Opening the unit up, the D9 has six leads going to the keyboard (pics 3 & 4)
    The Level II ROM set has hand-written labels ??? (pic 5)
    There is an add-on board mounted above the keyboard on the right side (pic 6) with lots of wires going to the slide switches and the motherboard (pic 7)
    The motherboard itself (pic 8 ) has a small added board and lots of extra wires (pics 9 & 10)
    This is the 5th Model I in my collection, but none of the others are anything like this one. Any thoughts/info appreciated.
    Mike
    May 2011
    Outer Mongolia
    2,061
    Just eyeballing it I'd guess the DB9 connector is for an Atari 2600-style joystick. (Looks to me like they soldered it so it'd actuate the directional arrows and the button is the spacebar.)
    The DE9 looks like an Atari joystick port, mapping the joystick directions to the cursor keys and fire to the spacebar.
    May 2011
    Outer Mongolia
    2,061
    I'd love to know what's on that white EPROM chip bodged onto the middle of the board. It looks like it's a 2kx8 2716-equivalent; if you PEEK around over the 12k mark (where ROM usually ends in a stock Model I) do you see signs that the ROM is mapped in there? Sometimes people would stick things like faster cassette routines or a keybounce fix onto a ROM and set it up so they could activate the contents by running a SYSTEM command after starting BASIC.
    Re: the switches, have you tried stopwatching a FOR loop with them in different positions? Some of that hacking could be a speedup mod. There is a remarkable amount of hacking, though, I must say.
    The keyboard stickers look like Scripsit keys to me. (Note: I did not spend more than two seconds thinking about this, and am possibly entirely wrong about it.)
    Jun 2015
    Sioux Falls SD
    366
    Where do the wires attached to the switches go?
    Jan 2011
    Portland, Oregon
    696
    My first thought on the DB-9 connected to the keyboard was for an Atari joystick. Something I'll check when I get it running more smoothly.
    All of the wires on the switches are visible, connected to the motherboard or the small add-on board. Both switches in forward position have no wires (normal mb operation?), in the rearward position they connect the add-on board to the motherboard.
    Mike
    Oct 2008
    Kamloops, BC, Canada
    5,945
    44
    Whoever did those mods did a *beautiful* job cutting the holes for the switches and joystick port.
    [Need something to waste time on? Click here to visit my YouTube channel CelGenStudios]
    [No time for videos? Click here to visit my Twitter feed @CelGenStudios]
    = Excellent space heater
  9. #9
    Jan 2011
    Portland, Oregon
    696
    Backside of the little board and the switches:
    Z26 is piggybacked with a 74LS74
    Z27 is piggybacked with a 74LS36
    Z55 is piggybacked with a 74LS02
    Everything that can be reseated has been, so on to reassembly and retesting.
    Mike
  10. #10
    Aug 2013
    Philadelphia,PA area
    118
    The EPROM appears to be in Z29's position, suggesting it is a character generator ROM replacement. It's probably a lower case ROM upgrade. Some of the mods around it may be for additional scan lines like the "Don Mod" from Australia supported.
    Tom
