Results 1 to 2 of 2
Thread: Hi. How do I get out of moderator jail?
    Default Hi. How do I get out of moderator jail?
    Does it happen if I post an intro? I guess I'll do that, then.
    Been computing since '81 or so, still have some fondness for some of the machines of that era. The "home computer" era, before the crash -- and before the dominance of PC compatibles. My fave is Sinclair, although I see there's not an area for that here. Second fave is TRS-80. But I kind of collect everything now. Or really, I did more collecting a few years back -- supplies aren't what they used to be (or maybe everything's just on eBay).
    Mar 2009
    Dublin, CA USA
    2,870
    Quote Originally Posted by wmcbrine View Post
    You make 10 posts that are approved my mods. I believe this was in the stuff you had to read when you agreed to when you signed up.
