Results 1 to 6 of 6
Thread: IBM PS/2 L40 SX Laptop Internal Batteries
    Default IBM PS/2 L40 SX Laptop Internal Batteries
    Greetings All !!
    I went to replace the CMOS battery in my IBM PS/2 L40SX Laptop only to discover that it actually has 2 separate batteries internally. It has one 3V Lithium battery and one 3.6v NiCd battery ? I have never seen any computer or laptop with 2 internal batteries like this. Can someone explain why there is 2 ? I am going to replace them both but would like to know what each does. I know one is for CMOS Clock backup but what's the other one for ?
    The 3V Lithium is very common, as I can purchase it online but, the other 3.6V NiCd is not. I am having a hard time finding a replacement. Anyone have a link to purchase this 3.6 NiCd battery ?
    Thank you !!
    Feb 2011
    2,341
    10
    The probably backs up the config. I assume this is in effect a MicroChannel machine so it has a config somewhere. Many NiCad are no longer made. You may be able to substitute NiMh..
    https://en.wikipedia.org/wiki/Nickel...admium_battery
    G4UGM
    5,890
    44
    Typically the 3.6v Ni-CD would hold the ram or CPU alive for a few minutes during a hibernation or sleep mode battery swap and the rest of the time the computer keeps it topped up.
    These days it's better to remove the battery because of how prone they are to leaking and not many of us still need to do live battery swaps.
    Feb 2017
    Guildford, U.K.
    294
    Like most portable computers it will have two batteries, the 3V one to retain the RTC/CMOS config data and the other (no longer recommended) for when there's no mains supply at hand. Forget about the latter, just take your mains transformer everywhere, if "going mobile".
    What "we" know about the L40SX is here:
    http://ps-2.kev009.com/ohlandl/8543/8543.html
    Cheers,
    Tim
    Thank you guys !! WBST - thank you for the link. I seen the diagram an it makes sense now. I replaced the backup battery and it's storing the RTC and CMOS settings just fine now. I will pull the standby battery out (to prevent leakage) and will not replace it.
    Thanks, again all !!
    Feb 2017
    Guildford, U.K.
    294
    Do check out Peter's ("Don" Peter Wendt's) suggestion to gut the battery pack and replace the innards with modern equivalents. It'll look pukka and do its job.
