Results 1 to 6 of 6
Thread: Hy-Tronix Myriad/xk 440 IC Tester
    Apr 2019
    Ottawa, Canada
    20
    Default Hy-Tronix Myriad/xk 440 IC Tester
    Hi guys,
    Thought I would post this here in the tools section. I purchased this from a local surplus store. I thought it was an interesting device, have never used one before but it should be able to test most SSI/MSI older logic ICs...
    Has anyone ever come across one before?
    edited to mention older SSI/MSI logic ICs. Thanks Chuck!
    33,454
    18
    "Most logic ICs"
    I'd amend that to say "most SSI/MSI older logic ICs". Many PROM programmers have the same functionality, but in actual practice are somewhat limited.
    Apr 2019
    Ottawa, Canada
    20
    Thanks Chuck,
    It did come with a few ICs that I will try out it in. It also came with a reference book of equivalent ICs from 1983.
    Some of the sample chips it came with:
    MC74BC00P
    MC74BC08P
    MC74BC32P
    MC74ACT74N
    MC74ACT245N
    SN7490AJ
    74AC00
    74AC244
    QB 8345
    RM747DC
    74AC241
    33,454
    18
    Don't know what a QB8345 is. Are you sure that isn't a date code?
    The chips above are either simple combinatorial logic or simple counters flip-flops latches and drivers. Try some really complex logic, say, a 74AS881.
    Still, they can be useful if you have a pile of house-numbered TTL that you're trying to identify.
    Apr 2019
    Ottawa, Canada
    20
    You are correct, I wrote the wrong number down as I hadn't seen either number before.
    QB8345, the actual part number seems to be 9007DM
    I don't have many logic ICs, just standard stuff (or, nor, and, flip flops etc).
    I tested a few of the ones it came with along with the self-test and it appears to be working.
    33,454
    18
    9007 = old Fairchild TTL logic family. 8-input NAND, but pinout somewhat different from 7430.
