Results 1 to 10 of 10
Thread: Disk ][: Paying the idiot tax
    Oct 2016
    Illinois, USA
    443
    Default Disk ][: Paying the idiot tax
    So, I offset the header on my Drive one Disk ][ while transplanting it and the controller from my 6502 IIe to my 65C02 IIe for cosmetic purposes. It sort of sounded like issue would be isolated to the controller, not the drives themselves, but the drives do the "Ram Track 0 repeatedly" power-up stuff then never actually attempt to read a disk. Any recommended reading for working my way out of the hole i've put myself in, or am I sticking to the UniDisk?
    General Failure Reading Drive C -
    Abort, Retry, Ignore?
    Oct 2016
    Illinois, USA
    443
    Ah, perfect. Thanks!
    Mar 2006
    Massachusetts, USA
    1,888
    A true PSA.
    Jan 2012
    Connecticut, USA
    2,401
    Just a little info that may help. I am familiar with the 74ls125 blowing on the disk II but it isnt always the culprit. Recently I looked at two DISK II internal boards I received that never worked; turns out it was the CA3146 IC right next to the aforementioned 74ls125 that was the culprit. I used a known good chip to test and the drive was working again. I ordered some from ALiexpress as replacements: https://www.aliexpress.com/item/4000...e3324c4d2GenIP
    If they work I will post details.
    Oct 2016
    Illinois, USA
    443
    Idiot tax: Paid. Thanks to the spares I got with the two needed chips, i'm ready if this ever happens again too.
    Jan 2012
    Connecticut, USA
    2,401
    So was it the 74ls125? Were they visibly blown?
    Oct 2016
    Illinois, USA
    443
    Yup to the former, nope to the latter.
    Mar 2012
    Augusta, Georgia, USA
    713
    I think any Apple II owner/collector has done this at least once.
    Jan 2012
    Connecticut, USA
    2,401
    Not having a keyed connector on the floppy card is just a bad idea.
