Results 1 to 10 of 11
Thread: Best way top mount TWO 1/2 Height floppy drives on an IBM 5150 ?
    Default Best way top mount TWO 1/2 Height floppy drives on an IBM 5150 ?
    Greetings All !!!
    Was wondering if someone can tell me the best way to mount two 1/2 height floppy drives in an IBM 5150 ? I would like to know if they sell a kit somewhere and if you have a link, or a link for something I can print up on a 3D printer possibly ? I don't want a hack job and would like it to look as it was factory done but I know this was not intended.
    Thank you !!
    Quote Originally Posted by MaCJaX View Post
    Greetings All !!!
    Thank you !!
    There actually was a factory part for it - just a piece of sheet metal with 4 holes on the side to secure the top drive to the screws for the lower drive. No idea where to get one now
    Here:
    https://iec.net/product/dual-drive-m...25-inch-drive/
    They have screws somewhere too.
    Here:
    $2 which is perfectly reasonable... until you add it to the cart and estimate shipping and its FIFTEEN FRIGGIN DOLLARS
    Did you update your address? I just bought like half a dozen things from them, they have St412 style MFM cables too, and I think shipping was like $7.45, which I'm guessing is a flat rate box.
    huh you're right that dropped it down to 7 something
    I have defiantly seen some "interesting" mounting arrangements. liberal use of Packing tape and all kinds of strange screws and weirdness.
    the large ring terminal sort of pinched the case of the 5160 and was the only thing holding the drive in place -_-
    Quote Originally Posted by pinkdonut666 View Post
    hey at least the ring terminal is made of metal, pot metal but metal nonetheless
    beats the hell out of tape or other nonsense
    33,689
    Terminals, like that shown, are made of copper usually with tinning or galvanizing. "Pot metal", generally known as "Zamac" is zinc+aluminum+other bits and is usually quite brittle. Useful for casting cheap parts, but little else to recommend it.
    A trip to the local hardware/big box store, a hacksaw and an electric drill is sufficient to "roll your own". A file or sandpaper to ease the edges if you will. Paint is optional.
    I had a more interesting problem with replacing a 3.5" hard drive with a 2.5" SSD. The adapters that I could find all seemed to use side-mounting, where my application required bottom-mount. I solved that one with a hunk of 3/8" acrylic sheet.
