Results 1 to 7 of 7
Thread: HiTech C for CP/M machine specific manual? Running on two disks question
    Default HiTech C for CP/M machine specific manual? Running on two disks question
    The main manual which I've been able to download suggests a hard disk or that it can run on two disks and then talks about an installation chapter in a "machine specific manual". Has anyone seen the machine specific manual? Does it exist?
    There is around 400K in files, does anyone know which files would go on DISK A and which on DISK B for it to work?
    Get yourself one of these: http://www.cpcwiki.eu/index.php/UIDE...Z-80_computers
    You might have to write some BIOS drivers but it's not that hard...
    Maybe a case of the blind leading the blind as I only came across these in the past month but depending how much configuration of the disk parameters you can do in the CP/M BIOS (not the ROM BIOS) you can just about make these Gotek drives do what you want.
    http://www.vcfed.org/forum/showthrea...Gotek-USB-disk
    See the later section of the thread
    Pete
    Jun 2016
    Guisborough, England
    226
    The answers here somewhat depend on what disk drives you have available.
    I've got an Amstrad PCW, and I bought the Hisoft C a long time ago, 198?, and I certainly was able to run it fine on my setup. However...
    I had a PCW 8256, but I had the extra RAM (and the 38? k ramdisk) and I also had a B: drive which was a 360k 5.25" external drive, so I had more than the normal drive space. I usually operated the C ALL on the B: drive, which was quite big enough. The RAM drive would also have been practical, but with extra copying. Using the 173k A: alone would have been more of a problem, but using M: for any temp files, and maybe swapping between write/edit the prog on one disk, and compile on another, would be practical. Just.
    I bought a version of the package aimed specifically at the PCW range, so I never saw any 'machine specific manual', maybe the whole package was such anyway?
    This question is somewhat academic now anyway as I have the uIDE device which attached to the PCW and provides 13 @ 8Mb virtual drives, so there's no problem. I also used the Eco-C package which was a more standard C system, although the Hisoft version was still useful for some things.
    Geoff
    Vintage Devices: Epson HX-20/TF-20, Amstrad PCW 8256 (with extras), 386 and 486 PCs with 5.25 and 3.5 floppy drives, Pentium 75 with Roland LAPC-I midi card
    I've got a pair of 390K drives on my Kaypro 2. I was playing around with a GoTek on it last night, but I think I'm probably not going to install it permanently and just stick with the dual floppies. The real issue then is a capacity issue - with 390K to work with, I would have to split the files up in the HiTech C to only have the ones you need to compile.
    Jun 2016
    226
    If you've got a pair of 390k floppies then I don't think you've got a problem. I think you could get everything you need on one disk, to edit and compile/link. If you like to have a number of projects live at the same time, or at least the source code handy for cut/paste, then you might need a little more space. I've got a working Hisoft disk here, 340k useable, and it's got 100k free even with the 'C' system, editor, source for a couple of projects, compiled .COM files, even some 'junk'.
    If you need more elbow room, then try what I've just seen for a 2 floppy Fortran system. The compiler executable files were on A:, and all called via an explicit A:hc or whatever. The default/current drive was set to B: and the other files used were on B, incl the .LIB(s).
    Try things with the one disk, see how that is.
    Of course, if you're trying to do something with a large source file then you'll often need double the size of that available.
    Geoff
    Jun 2016
    226
    Aaargh - just realised. OP here was asking about HiTech C. My comments are referring to HiSoft C. I think these may be two quite different products.
    The HiSoft product will certainly operate within the two disk parameters, as will the Eco C product that I also have. I don't know about the HiTech product, which I've not seen.
    Sorry about any cunfusion caused.
    Geoff
