Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Anyone savvy with the TL866A Mini pro willing to shed some light?
    Jan 2012
    Connecticut, USA
    2,537
    Default Anyone savvy with the TL866A Mini pro willing to shed some light?
    So I have had the TL866A Mini pro programmer for a year and a half now. I primarily use it to test logic chips. I would finally like to get into ROM programming. I have some Apple IIc boards which have the original 255 ROM which is rather limited. After Watching one of Adrian Blacks' newest videos :https://www.youtube.com/watch?v=N8YVX75Qr-0&t=1112s
    He burned a new custom ROM in the video which I would like to give a try. But to be honest I am not entirely sure which eeproms are supported or will work. Right now the only erasable eeproms I have are two JL27C256D (which I took from a non working Zenith board, and four M2764A-2F1 Which I bought new. Problem is when I try to look these up under the chip selection I don't find either.
    I realize I am a complete newb with burning roms so would appreciate any info you all may have on this.
    Dec 2010
    Seattle, WA
    1,953
    An STMicroelectronics M2764A-2F1 is a fairly common EPROM. I would be surprised by a decent device programmer which doesn't have a programming algorithm for that specific device.
    A JL27C256D is probably a TI TMS27C256 device, which is also a very common EPROM. From the TMS27C256 device datasheet a JL suffix would indicate a ceramic DIP package with an operating temperature range of 0C to 70C.
    I have never used a TL866A. The BP Microsystems device programmers I use will check the JEDEC manufacturer and device codes and give you a warning if you attempt to program a device using a selected programming algorithm that does not match the ID codes of the device. Programming a device with an algorithm for a different device will probably result in a failure.
    The guys over at the eevblog.com forum know a huge amount.
    Oct 2017
    Kentucky USA
    104
    I found that unit to be pretty good although it doesn't do 21 volts for early 2716's. I made an adapter for it so that can.
    I'm pretty sure that the M2764A-2F1 is doable like any other 2716 (EXCEPT THE TI 2716!) at 12.5 volts but no guarantees.
    Generally speaking, a 27C256 is a 27C256. Doesn't matter which manufacturer
    Jan 2012
    Connecticut, USA
    2,537
    So it doesnt matter which vendor I choose under the pull down menu (as long as its the correct # of pins)?
    Dec 2010
    Seattle, WA
    1,953
    YMMV with that.
    My BP Microsystems device programmer certainly has a variety of manufacturer approved programming algorithms for different 27C256 devices. Partial list below:
    Manufacturer: AMD (ID=1h)
    Part Number: Am27C256 (ID=10h)
    Algorithm name: Quick Pulse
    Pulse width: 100us
    Vcc(program): 6.25
    Vpp(program): 12.75
    Manufacturer: Atmel
    Part Number: AT27C256
    Algorithm name: Fast (1)
    Pulse width: 1ms + x*3ms
    Vcc(program): 6
    Vpp(program): 12.5
    Manufacturer: Cypress (ID=34h)
    Part Number: CY27C256 (ID=1Ah)
    Algorithm name: Fast (2)
    Pulse width: 200us + x*400us
    Vcc(program): 5
    Vpp(program): 12.5
    Manufacturer: Fairchild (ID=8Fh)
    Part Number: NM27C256 (ID=4h)
    Pulse width: 100us
    Vcc(program): 6.25
    Vpp(program): 12.75
    Manufacturer: Fujitsu
    Part Number: MBM27C256
    Pulse width: 1ms + x*1ms
    Vcc(program): 6
    Vpp(program): 21
    Part Number: MBM27C256A
    Vcc(program): 6
    Vpp(program): 12.5
    Manufacturer: Generic
    Part Number: 27C256 (12.5V)
    Vcc(program): 6
    Vpp(program): 12.5
    Manufacturer: Hitachi (ID=7h)
    Part Number: HN27C256AG/HG (ID=31h)
    Vcc(program): 6
    Vpp(program): 12.5
    Manufacturer: Intel (ID=89h)
    Part Number: 27C256 (ID=8Ch)
    Pulse width: 100us
    Vcc(program): 6.25
    Vpp(program): 12.75
    Manufacturer: Macronix (ID=C2h)
    Part Number: MX27C256 (ID=10h)
    Pulse width: 100us
    Vcc(program): 6.25
    Vpp(program): 12.75
    Manufacturer: Microchip Technology (ID=29h)
    Pulse width: 100us
    Vcc(program): 6.5
    Vpp(program): 13
    Manufacturer: Mitsubishi (ID=1Ch)
    Part Number: M5M27C256P (ID=1h)
    Vcc(program): 6
    Vpp(program): 12.5
    Manufacturer: National Semiconductor (ID=8Fh)
    Pulse width: 100us
    Vcc(program): 6.25
    Vpp(program): 12.75
    Manufacturer: NEC (ID=10h)
    Part Number: uPD27C256 (ID=A4h)
    Vcc(program): 6
    Vpp(program): 21
    Part Number: uPD27C256A (ID=64h)
    Vcc(program): 6
    Vpp(program): 12.5
    Manufacturer: OKI
    Part Number: MSM27C256
    Pulse width: 100us
    Vcc(program): 6.25
    Vpp(program): 12.75
    Manufacturer: Philips Semiconductors (ID=15h)
    Pulse width: 100us
    Vcc(program): 6.25
    Vpp(program): 12.75
    Manufacturer: Seeq (ID=94h)
    Part Number: 27C256 (ID=C2h)
    Vcc(program): 6
    Vpp(program): 12.5
    Manufacturer: STMicroelectronics (ID=20h)
    Part Number: M27C256B (ID=8Dh)
    Pulse width: 100us
    Vcc(program): 6.25
    Vpp(program): 12.75
    Manufacturer: Texas Instruments (ID=97h)
    Part Number: TMS27C256 (ID=4h)
    Algorithm name: Snap
    Pulse width: 100us + 100us
    Vcc(program): 6.5
    Vpp(program): 13
    YMMV with that.
    Indeed, that's why I said generally. None of them are going to cause any harm to the chip, it's worth trying in any case if the specific manufacturer isn't listed
    Jan 2012
    Connecticut, USA
    2,537
    Well there is no harm in trying. Anyone have any advice for erasing/blanking an eeprom? I dont own a UV erasing device.
    https://www.ebay.com/itm/Oral-SteriC...A/324039714370
    2 cycles in this baby does the trick, it can fit about 4-5 ICs at a time
