Results 1 to 10 of 13
Thread: this 5155 screen, easily fixable?
    Feb 2020
    Between Barcelona and Bilbao, Spain
    16
    Red face this 5155 screen, easily fixable?
    Hi,
    I'm in the mood of buying a 5155 portable, i found one at a fair price but the owner showed me that the CRT is broken.
    I think it may be the power supply, the p12 connector I read in another thread. What are your thoughts?
    Would you pull the trigger and buy it at 250 price? It comes as-is, no disks and no manuals.
    Image of the screen:
    Thanks!!
    Sep 2016
    Shrewsbury, MA
    1,179
    Seems like the CRT is fine, but something else is wrong. The CRT looks normal for when you have the brightness and contrast turned up all the way
    6,526
    Quote Originally Posted by shine View Post
    The P12 connector (supplies +12V to the display) problem that has arisen at least twice, results in the 5155 booting, text seen on the display, but the text is 'jumping up and down slightly'.
    6,526
    Does the 5155 appear to be starting?
    So, about a minute after power-on, the floppy drive LED is expected to turn on for a little while (as the motherboard's power-on self test checks the drive).
    Feb 2020
    16
    Yes it boots, the floppy disk light turns on.
    Feb 2020
    16
    smells like it won't be that "easily"....
    If the computer boots up, it could be the connector from the screen to the CGA board is loose or not connected.
    6,526
    You are asking the question of something that needs to be repaired. I can repair these things myself down to component level, and so the cost to me would be about 250 (plus my time). We can provide some diagnostic guidance, etc. to you, but in the end, we may be telling you that you need a new motherboard (for example), and so the true cost of the 5155 to you (or others) could be say, 350, or more.
    Based only on the symptom shown by the photo, some single-failure possibilities that I can think of:
    If the motherboard's power-on self test (POST) is observed to be checking the A: drive:
    * Video cable has fallen off the IBM CGA card.
    * Faulty IBM CGA card.
    * Faulty display unit.
    If the motherboard's POST is not observed to be checking the A: drive:
    * Power supply problem (faulty, but at least +12V being supplied).
    * Motherboard problem - Socketed chips need to be re-seated.
    * Motherboard problem - Faulty RAM in first bank.
    * Motherboard problem - Short circuit tantalum capacitor. <------ Common
    * Motherboard problem - Corrupted ROM chips.
    * Motherboard problem - Other.
    * Expansion card problem - Faulty in a way that overloads power supply (e.g. short circuit tantalum capacitor).
    * Expansion card problem - Faulty in a way that interferes with address/data bus operation.
    6,526
    Your moderated posts have appeared.
    And expected as well, would be a single beep from the speaker, at roughly the same time as the LED turns on.
    Revisiting some of possibilities that I listed in my previous post:
    Photo at [here].
    Faulty IBM CGA card
    Assumption: Motherboard good, and motherboard's video switches set for CGA.
    Card substitution would be the quickest way to test that.
    There is only one socketed chip on the IBM CGA card. It would be worth re-seating that chip.
    Connecting a CGA monitor to the IBM CGA card's DB connector, or connecting an NTSC composite monitor (or NTSC compatible TV) to the card's RCA connector, would be revealing.
    If required, a replacement CGA card does not need to be an IBM one. There are some CGA cards that have the required connector.
    Faulty display unit
    We know that the display unit is getting +12V.
    Diagnosis would require the use of an oscilloscope.
    6,526
    My "Assumption: Motherboard good, and motherboard's video switches set for CGA." in the previous post, raises two other possibilities:
    Motherboard's video switches set incorrectly
    Need to be set for CGA.
    If incorrectly set for MDA, an error beep pattern of '1 long beep then 2 short beeps' would be heard from the speaker very shortly after the 5155 is powered on.
    If incorrectly set for EGA, no error beep pattern will be heard.
    Confirm correct switch settings.
    Faulty motherboard
    The motherboard's video switches could be set to CGA, but faulty/dirty switches, or faulty switch support circuitry, result in the POST believing that the switches are set for MDA or EGA.
    If set to CGA, and the POST believes that EGA is set, then even with no display to work from, it should be possible to prove the scenario. Without a boot disk, the 5155 will jump to Cassette BASIC. Even though one cannot see the screen, certain BASIC statements can be entered, to first prove that BASIC is running (by entering a BASIC statement that beeps the speaker), and then to enter conditional statements that interrogate the switches and beep the speaker if True.
