Results 1 to 6 of 6
Thread: YD380 1710 help jumper
    Default YD380 1710 help jumper
    Hi all
    I try to connect a YD380 1710 on a motherboard ASUS
    But I do not know if I use the good flat cāble (twisted or not)
    and how to put the correct jumper : DS0 DS1 DS2 DS3 HS HM MX HD INU HL TD MR
    and also if I must connect the terminator resistor ?
    I did not find any documentation about the jumpers
    Thank you very much
    Patrick
    Dec 2005
    Toronto ON Canada
    7,290
    If it's the only drive, after the twist on a twisted cable, DS1, terminator in; hopefully the other jumpers are correct as is.
    Thank you MikeS
    I try tomorrow
    And if it is the second disk : before the twisted cāble and the jumper DS?
    Thanks
    6,526
    Some later motherboards support only one floppy/diskette drive. And some of those may require the use of an untwisted cable.
    Refer to the motherboard's user manual. If you do not have that, then you may need to experiment.
    Sep 2012
    Indiana, USA
    511
    Standard PC floppy drives are jumpered as DS1. In two drive setups, the twist in the cable is what swaps the drive assignments. Both drives set as DS1, the one before the twist is DS1, and the one after the twist (on the end of the cable) is DS0.
