Thread: Amiga 500 50hz to 60hz power supply?
    Lightbulb Amiga 500 50hz to 60hz power supply?
    i'm planning on buying an Amiga 500 from the UK which is probably with a 50hz 240v power supply. Our mains supply here in the Philippines is 220-240v 60hz. You've probably guessed my question, will the power adapter from UK works with a 60hz power supply?
    Yes. The frequency of the AC mains supply doesn't matter. But what may make a difference to you is that the Philippines is an NTSC country while the UK is PAL. So if you intend to use a TV as your monitor you may run into trouble with that.
    You can get around PAL / NTSC issues by using an RGB connection from the computer to the monitor. Those issues only come into play when using an RF or composite video connection to the TV \ monitor.
    There may still be the issue of whether the TV / monitor can handle 50Hz frame rate as opposed to 60Hz for machines and monitor / TVs from NTSC countries.
    Quote Originally Posted by vwestlife View Post
    Yeah but most modern TVs have PAL support, right?
    Quote Originally Posted by pororo View Post
    Most, but not all. Some will only show it in black & white, or won't show any image at all.
