Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: All about DSKs
    Mar 2012
    Augusta, Georgia, USA
    712
    MMCPM232.DSK boots fine in TRS32. It may be something about the old DOS emulator where it's not interpreted correctly.
    It appears to me that the MMCPM232.DSK file is in DMK format, while the ld4-631.dsk file is in JV3 format.
    Descriptions of the formats can be found here:
    https://www.tim-mann.org/trs80/dskspec.html
    and here:
    http://www.classiccmp.org/cpmarchive...ical-DMK-disks
    There is (at least) one other common format, and that is JV1 (description in the first link above).
    In my experience, TRS80 related .DSK files are generally in one of these 3 formats.
    Best of Luck!
    Feb 2015
    Cleveland, OH, USA
    1,035
    Quote Originally Posted by GeoffB17 View Post
    I've had a look at the two images, and they could be different in structure, but not THAT different. But, if one loads, and the other does not, then I'll accept that they are too different.
    However, be advised, if you are trying two different formats of .DSK file, then there is a third type that is REALLY different. The Amstrad CPC (and PCW machines) makes use of it's own .DSK format, at least this format includes a header which specifically refers, in ASCII text, to CPC EMU or CPC EMU EXTENDED, so you can see immed what it is.
    Geoff
    I had to leave off the ASCII due to size limitations of the images, but the ASCII really shows the difference between the two files. I was hoping there would be a header explaining something, as with a Dunfield IMD file, but that does not appear to be the case.
    For whatever reason the LS-DOS file loads and the other does not. At least on this (Reed's) emulator.
    Thank you for your observations. Learning as I go.
    -CH-
    Feb 2015
    Cleveland, OH, USA
    1,035
    Quote Originally Posted by kizmit99 View Post
    and here:
    Best of Luck!
    That explains a lot. Thanks for your reply.
    -CH-
  5. #15
    Feb 2015
    Cleveland, OH, USA
    1,035
    Quote Originally Posted by rittwage View Post
    I'll give it a shot; I realized yesterday that it would be handy to run an emulator on the Windows 10 machine as well. Thanks for your suggestion.
    -CH-
