Thread: A guy walks into a bar...
    Feb 2015
    Cleveland, OH, USA
    1,113
    Default A guy walks into a bar...
    ... and says "Anybody got any information on the Everx EV-125 Multi-IO Card?" Or might as well have, 'cuz he'll get the same amount of information as if searching the Internet. ***
    I know this topic has arisen here several times before, but I just want to post what I have learned and ask a few relevant questions:
    In another thread I described the troubles I had trying to sort out the source of parity errors occurring on my 5170. After attempts at configuring an AST RAMPAGE 286 I removed, cleaned, replaced, retested - nada.
    Back to the drawing board I dug out an Everex EV-125 which has COM x 2, LPT and game ports in addition to room for four banks of RAM. Documentation everywhere is the same as what is on STASON.ORG https://stason.org/TULARC/pc/io-card...rd-EV-125.html, which is pretty terse. The card has a forest of jumpers and most are unexplained. The ones that ARE indicated are somewhat confusing, so there was a lot of trial and error. Here is what worked for me on a 512KB AT:
    Base memory selection: Jumper block W3; pins 2:3, 4:5 ALSO jumper block W1, position 6, open - indicating 512k on board
    Added memory configuration: Jumper block W1; pos. 1 OFF, 2 ON, 3 ON, 4 ON, 5 ON - indicating 2 MB (four banks of 18 ICs) **
    Existing memory configuration: DIP Switch block SW1; pos 1 ON, 2 ON, 3 ON, 4 OFF - indicating 0-1 MB
    Extended memory fraction selection: DIP Switch block SW1; pos 5 ON, 6 ON, 7 ON - indicating 0KB extended memory
    Base memory backfill: DIP Switch SW1; pos 8 ON - indicating backfill to 640 from 512
    The remaining jumpers mentioned in STASON were configured the same on my board.
    With these settings I was able to boot and use the system without generating parity errors. By setting W3 correctly and enabling SW1/8 my (AMI) BIOS recognized 639K base memory and 1536K as extended. I do not have any memory managers loaded, but MSD recognizes this configuration as well.
    I do not have any Everex software for the board and I don't know what the other jumpers on the board do. There may be an address conflict with one or more of the ports as well, but I haven't gotten that far. If necessary I can change the addresses and IRQs of the SIIG drive controller.
    ** Now for the question: The STASON docs refer to banks of memory as populated with 4464. My board has 41256s. The only way this would work, that I can see, is if the 4164 are 64x4 and the 41256 are 256x1. Is that what's going on?
    *** Offering a reward for a copy of the original Everex EV-125 documentation.
    HTH
    -CH-
    Quote Originally Posted by clh333 View Post
    Sorry, but you can't make up your own facts as you go along.
    4164 = 64x1
    4464 = 64x4
    Feb 2015
    Cleveland, OH, USA
    1,113
    Point taken: 4464. Excuuuuuse me!
    Got a manual?
    -CH-
    Outer Mongolia
    2,048
    Considering the card seems to have four banks of 18 chips I think it's highly unlikely Statson is correct about the card accommodating 4464s. I've seen cases where a pair of 4 bit wide chips like 4464s and 44256s were combined with a single 4164/41256 to get the standard 9-bit Parity RAM banks that PCs expect, but it'd be *weird* to build a RAM bank out of 8x 4464s and a single 41256 doing parity for all four "sub-banks".
    Feb 2015
    Cleveland, OH, USA
    1,113
    After more experimentation I have confirmed that the EV-125 in the STASON configuration has serial ports A and B (external) addressed as COM1 (3F8h) and COM2 (2F8h) and that they were active, although masked by the SIIG ports which were configured the same. I moved the SIIG ports to COM3 and COM4 and now each is recognized; I was able to install the MS serial mouse on COM1, for example.
    I tried running the Everex EV-158A software to install an EMM but was unsuccessful. Either I'm not using the correct syntax or there is a software incompatibility. So far the only contribution of the EV-125 is to bring base memory to 640.
    I have not examined the parallel port yet.
    -CH-
