Results 1 to 10 of 28
Thread: 5150, xt-ide, 500mb hd. Can't delete 10 mb partition
    Nov 2009
    Dublin, Ireland
    973
    Default 5150, xt-ide, 500mb hd. Can't delete 10 mb partition
    See title. Using fdisk fails to delete partition. Also tried on a486 with dos 6.22.
    Have you tried WipeDisk?
    https://www.lo-tech.co.uk/wiki/WipeDisk
    Nov 2009
    Dublin, Ireland
    973
    Quote Originally Posted by mcs_5 View Post
    Just discovered it. Will try it tomorrow.
    Nov 2009
    Dublin, Ireland
    973
    Quote Originally Posted by fjk61011 View Post
    I used wipedisk on the 511 drive on my ps/1. . Fdisk made a 511 partition. Formatted it with pc dos 4.01. Transferred drive to the 5150 and it boots up.
    4,796
    Always use WIPEDISK or equivalent to destroy old partition data, especially if the disk/CF/whatever was previously used in a more modern system.
    33,656
    I just use the following debug script:
    -f200l200 0
    -a100
    0931:0100 mov ax,0301
    0931:0103 mov bx,200
    0931:0106 mov cx,1
    0931:0109 mov dx,80
    0931:010C int 13
    0931:010E int 3
    0931:010F
    -g=100
    It's easier to do this rather than to go looking for a specific program.
    Nov 2009
    Dublin, Ireland
    973
    I changed the IDE cable to the centre connector and have full access to the disk.
    Nov 2009
    Dublin, Ireland
    973
    I've tried installing MS-DOS 5.00, however it won't boot. Tried SYS and FDISK /mbr. No luck.
    No error message(s)?
    Nov 2009
    Dublin, Ireland
    973
    Let me check.
    EDIT BOOTING C>>C
    Then it hangs.
