Results 1 to 7 of 7
Thread: XT-IDE (Lo-Tech) and Error 1h!
    Nov 2009
    Dublin, Ireland
    1,030
    Default XT-IDE (Lo-Tech) and Error 1h!
    I've googled and searched the forum.
    I have an XT-IDE card (Lo Tech) and get an error 1h! after the bios screen.
    Any ideas to what this means?
    Nov 2009
    Dublin, Ireland
    1,030
    I changed the IDE cable to the centre connector and have full access to the disk.
    I have the same issue. I'm trying to get one to work in a Cordata CS40 (XT - compatible) with no luck. The bios shows up and I can select my boot preference but never recognizes the CF card. Even purchased a card from a guy that makes these and ensures them working. Can't find much info on this computer but looks similar to the Leading Edge model M I think. I tried the card in all four slots. I have to use this solution as the HD is on it's way out. What do you mean by "changed the IDE cable to center connector", changing slots? I too have the XT-IDE from lotech and the adapter from texelect which works with the lotech card.
    Nov 2009
    Dublin, Ireland
    1,030
    Quote Originally Posted by Topsock View Post
    On the cable the centre connector is the slave for the ide drive
    Found my issue, was a jumper setting that i had no information on. Thought it was for the real time clock so never messed with it. I removed the jumper and boom all is good
    6,608
    Quote Originally Posted by fjk61011 View Post
    Are you writing about 'cable select' operation, per [here] ?
    No motherboard jumpers. Seems there are many different setups that did not follow ibm/xt standards.
