Results 1 to 10 of 79
Thread: PET 4016 power in from transformer to Jumper 8
    Default PET 4016 power in from transformer to Jumper 8
    I'm trying to revive a PET 4016. I've found the voltage regulator schematics, but i cannot find the expected voltages IN to jumper J8 from the transformer.
    connector from transformer to J8:
    1 2 3 4 5 6 7 8 9
    brn red blk red brn blk key blue blue
    2 and 4 go through the filter capacitor.
    what i measure:
    1 to 5 = 18 vac
    8 to 9 = 17 vac
    3 to 2 or 3 to 4 = 0.5 vac
    I think 2/3/4 should provide 5vac?
    any help is appreciated.
    3,553
    No,
    Between pins 2 (positive) and GND (i.e. across C17) you should see about 9 Volts DC (not AC).
    +9V (unregulated) is produced by CR1 and CR2 and then sent back out of connector J8 on pin 4. It then goes to the large external smoothing capacitor and back into the board again (via J8) where it is fed to the two (2) +5V regulators.
    Although (whilst writing this) something is 'needling' me about pin 4...
    I will give you a definitive answer when I get home and have a look for sure...
    Ah! I see you have also mentioned pins 2 and 4 in your post.
    It may just be that your meter is set to AC rather than DC. You are not reading the transformer output at these points but the rectified output.
    Thanks for the reply.
    Note that I am just trying to verify the transformer voltages and connector positions at this point. Not connected to the pet board yet.
    Dec 2005
    Toronto ON Canada
    7,291
    Quote Originally Posted by Dokken View Post
    Dave was assuming that it's connected to the board.
    Your readings are fine; pin 3 is effectively not connected to either transformer winding. In any case you would not see 5VDC anywhere; if it were connected you would see ~9VDC across the capacitor (1-4 and 5-4 rectified) as Dave pointed out.
    3,553
    True, I was...
    The rectified DC voltage will be about (1.4*ACV)-Diodes. If half wave the diode is about 0.6V. If center tapped full wave, the Diode is 0.6V. If a full wave bridge ( 4 diodes ) Diode is 1.2V.
    5V usually uses a center tapped full wave, so at the filter cap would be about 8.5V to 9V. This would be a voltage to the center tap of about 6V.
    Dec 2005
    Toronto ON Canada
    7,291
    ...5V usually uses a center tapped full wave, so at the filter cap would be about 8.5V to 9V. This would be a voltage to the center tap of about 6V.
    That's about right; the no-load AC voltage of the 5VDC is 1/2 of the 18VAC between pins 1 and 5.
    And a correction: pin 3 is ground and connected to the transformer, but not to the DC connections 2 and 4.
    In any case, the readings are correct; time to plug it in and look for smoke
    Thank you so much for your comments. FYI this is an 8032080 board.
    Plugged it in, and i get the this on the display.
    https://imgur.com/a/0j5rmwL
    Checking J11 (raw power), schematics say 1/4/6 should be +9vDC. I get + 7.5vDC.
    on J10 (raw power), schematics say 1/2 should be -5vDC. I get -13vDC.
    on J10 (raw power), schematics say 4/5 should be +16vDC. I get +21vDC.
    Thanks for any other test points or ideas on what's going on.
    3,553
    J10 1/2 should be -9V unregulated.
    The voltages are a little high however.
    Check for the correct dc voltages after each regulator.
    Note that there are two (2) +5 Volt lines in addition to the +12 Volts and -5 Volts.
    I would also check the dc voltage on the monitor board after the regulator as well. What monitor board revision have you got as it appears this PET has been upgraded if it has an 8032 main board installed.
    Do you have access to an oscilloscope to be able to look at the H and V drive signals on J7? I suspect a monitor fault with the display, but checking the drive signals will tell us for sure.
    The display is indicating a good ‘random’ pattern from what I can see, indicating that the video circuits are OK. But, the CPU appears not to be executing instructions properly - but we will get to that later...
    Dec 2005
    Toronto ON Canada
    7,291
    ...What monitor board revision have you got as it appears this PET has been upgraded if it has an 8032 main board installed.
    I think it's a 4016 'Fat 40' which use a 'universal' 80/40 board.
