Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: minimal F-11 SBC ?
    Dec 2010
    Colorado Springs
    166
    Thanks Dave!
    However, I'm thinking that those docs are describing the LSI-11, not the F-11. I just checked, and some of the LSI-11 chips actually have the 1600-series part number on them.
    Am I confused? Or, is the assertion that the F-11 is also a WD design using the same architecture?
    I've got some F-11's that have an "AMI" brand marking (some just say "DEC").
    Pete
    Jun 2012
    UK - Worcester
    3,543
    >>> I thought the LSI was the MCP-1600 but the F11 was DECs own design?
    Pass... I may have been meaning the LSI as opposed to the F-11 of course...
    >>> Thanks for the reference to the Soha & Pohlman paper - looks like the next step after the LD12. :>)
    Not likely !
    I have a few days off (Mondays and Fridays) so I am working on the LD12 a bit more (in between real work of course)...
    Incidentally, do you know what size of jack socket the 'logic probe' connector is? I am assuming a 'mono 1/4"' from the photographs? This is the last part of the puzzle for the front panel - although I have to re-lay the FP out (yet again) as I require a bit more space.
    Jun 2012
    UK - Worcester
    3,543
    A bit more investigation and I can confirm you are correct.
    The F-11 chip is the "11/23" which is a DEC part.
    The LSI-11 is the DEC/WD MCP-1600 parts.
    Sorry for the confusion .
    Sep 2019
    Zurich, CH
    108
    Quote Originally Posted by cbscpe View Post
    Correct. And also, the MCP-1600 cannot, out of the box, run PDP-11 programs. For that you need the DEC microcode chip. It's just that the LSI-11 was based on the MCP-1600, with DEC microcode.
    See https://en.wikipedia.org/wiki/PDP-11#LSI-11
    The LSI-11 was used in the PDP-11/03.
    The F-11 was used in the 11/23 and 11/24, the Pro-325 and Pro-350, as well as various embedded stuff.
  5. #15
    Apr 2017
    Switzerland
    282
    Quote Originally Posted by bqt View Post
    But the microcode was in standard MCP 1600 microcode ROMs, so you could actually read them and disassemble. would be interesting to have a look how they implemented a PDP-11 in MCP-1600 microinstructions. I will ask a collegue who got two LSI11/02 to borrow one so I can copy the ROM.
    For more information about my projects see https://www.5volts.ch
  6. #16
    Dec 2010
    Seattle, WA
    1,944
    Eric went through that exercise with the LSI-11 microcode 4 year ago. One complication is that there are application specific translation PLAs in the control chip which at the time had not yet been dumped. Just the microcode alone is not sufficient for complete knowledge of the implementation.
    Microcode, DEC LSI-11
    https://github.com/brouhaha/lsi11uc
    Disassembler for Western Digital CP16xx/WD21xx Microcode
    https://github.com/brouhaha/cp16dis
