Results 1 to 6 of 6
Thread: GMB-486UN - question about the external battery
    Default GMB-486UN - question about the external battery
    Hello,
    I'd like to add an external battery on my old 486 computer. The mainboard itself is a GMB-486UN, which had a barrel battery. Due to the battery leaking, I want to add an external battery. I now have problems identifying what I exactly need.
    The conector JP1 has the following PINs:
    -Pin1: VDD (6V)
    -Pin2: Unused
    -Pin3: Ground
    -Pin4: Ground
    As I already read in multiple sources, there are 4,5V and 6V possibilities for Pin1. According to my manual of that board I have the 6V.
    And I also read different solutions for adding an external battery. Since I'd like to add a rechargeable battery (there are many 3,6V rechargeable batteries on the market) I don't think that I need a diode between the + of the battery and the +6V-PIN.
    All I want to know is, is it really that simple connecting a new 3,6V rechargeable battery to the board (+ on the +6V-PIN and - to ground) or do I need to add any other components? I already tried to search for suitable batteries and found the Varta 3/CP300H which I would choose. The only thing which confuses me is that the connector has 6V, but the battery only 3,6V.
    Or may I just use 3x 1,2V AA rechargeable batteries with a diode? Can anyone recommend me something?
    6,607
    Quote Originally Posted by Ghirahim View Post
    Hello,
    Welcome to these forums.
    ... Due to the battery leaking, I want to add an external battery ...
    ... The conector JP1 has the following PINs: ...
    Yes, the user's guide for the GMB-486UN indicates that JP1 is for an 'external' battery.
    Read the information at [here].
    From that, the 'external battery' connector is designed for a non-rechargeable battery (no battery charging circuitry for the 'external battery' connector).
    Also, there is a possibility that 3.6V is not enough voltage for the 'external battery' connector of the GMB-486UN. The user's guide for the GMB-486UN simply indicates "6V". How much lower than 6V that you can go depends on the design of the GMB-486UN
    Some possible options are shown at [here].
    6,607
    No other components are required if you want to go down the (unusual) route of connecting a rechargeable battery to a connector that will not charge the battery.
    As I stated before, there is possibility that 3.6V may be inadequate for your motherboard.
    Also, if the battery has been 'sitting on the shelf' for a long time, the 3.6V battery may have self-discharged to a voltage significantly lower; the seller expecting that a rechargeable battery is going to be connected to circuitry that occasionally charges the battery.
    All you really need is a battery holder with three or four AA batteries. Either will work. They're easy to find and cheap on eBay.
    34,143
    I must be getting old--I'm pretty sure that this question has been asked and answered at least a dozen times over the years.
    Right on both counts...
