Thread: PC104(?) Megatel 8088 ( NEC V40 ) Board - any info?
    Default PC104(?) Megatel 8088 ( NEC V40 ) Board - any info?
    Hello,
    I have stumbled today on this board, I have found some information, but not many about this particular device. I belive it is PC104 board, but it's connector have 3 rows, and also it has additional two row 64 header (probably SCSI connector as i can guess from specs). Maybe someone could provide me with some technical details or pinout of this 3 row header? It would be great to test this board
    Jan 2005
    1,845
    I'm not claiming to be any sort of authority, but isn't that off for pc-104? Too big and oblong.
    It is entirely groovy regardless. Sorry I can't help.
    Incidentally I believe the v40 is something of a replacement for the 80186 or 80188. The v20 was a drop in for the 8088, the v30 for the 8086. My Ampro LittleBoard/PC has a v40.
    Aug 2013
    Philadelphia,PA area
    126
    PC-104 has a specific footprint for mounting the stacked PCBs. Your board doesn't have the connectors or the 4 mounting holes, so its just a single board computer with I/O connectors. SBCs with PC-104 expansion do exist, but the write up says there is an adapter card to provide the expansion footprint.
    HTH,
    Tom
    the 3 row looks more like the male side of a eurodin connector without the shroud
    34,140
    Sui generis. The board is a Megatel Quark PC (Canadian outfit) single-board computer.
