Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: L2 Cache questions
    Apr 2015
    Austin, Texas
    1,930
    You should verify if the chips are the correct type and if you have TAG RAM installed. Cache won't work without TAG chips, usually there's at least one, sometimes two.
    Jan 2012
    Aussie living Spain
    144
    Solved. I replaced all the cache chips and now cachechk see L2 cache. Probably one of the chips where bad but I only had 20ns space so I replaced the 15ns with 20ns. The motherboard notes 20ns or less so all working great. Now my 486 is rocking..
    Thanks for all your help guys.
    Not all those who wander are lost. - J. R. R. Tolkien
    Apr 2015
    Austin, Texas
    1,930
    20ns SRAM is good up to 50 MHz, so you can run basically any CPU available on the 486 platform without problems, even the DX 50, assuming everything can tolerate the 50 MHz bus.
    Jan 2012
    Aussie living Spain
    144
    ok, I'm running a DX2-66 Intel.
