Results 1 to 2 of 2
Thread: Replacement pins for TRS-80 Model 3 FDC port
  1. Default Replacement pins for TRS-80 Model 3 FDC port
    Hello, I have a Model 3 motherboard where the data port for the FDC flat cable has pins which have broken from the socket to the motherboard. I removed the bad socket, however I need to find a replacement. Either an entire socket to re-solder, or if anyone knows what the little metal pins are that push into the socket. They have a prong that sticks out the back of the plastic housing and the front of them is where the cable contact slides in. If I can find them, I could replace them in the socket I have and then re-solder it to the board.
    Does anyone know what the socket is called, or where I could find it or the pins? Thank you so much!
    Are you speaking about the 20 pins idc connector on the motherboard ? (where flat cable connects to motherboard?)
    Gaming: i7-8700K, 16GB, 1TB SSD, RTX 2060, Dual 27" LG IPS Monitors.
    Vintage: TRS-80 MODEL 4, 128K RAM, 360K FDD, Gotek USB FDD, FreHD HDD, RS232-WIFI MODEM, DWP-510.
    Programmer: Dell Inspiron 660S i3-3220 with 16GB Ram, running a BK-844USB & EP-2A-88.
    Web Site: https://texastandyrestoration.com/
    Facebook Page: https://www.facebook.com/TexasTandyRestorations/
