Page 7 of 7 FirstFirst ... 34567
Results 61 to 69 of 69
Thread: Computer Fun
  1. #61
    Oct 2013
    Miami, FL
    2,533
    Cool
    Upgraded the 15 NEC LCD to a 19 NEC LCD. The Roland modules made it to NY from JP. So hopefully in FL soon. Waiting for a Pentium 166 to arrive from the UK. Played some more Warlords II: > turn 105 in this particular game: very repetitive after a while: somewhat of a stalemate with the AI so will need to come up with a better strategy.
    Off topic: experienced overheating issued with a ZR30w today. Adding two fans to blow air into the power supply and inverter may have solved it. Will try again tomorrow. Waiting for DP cables and a W500 PSU so I can set it up as a workstation. Forgot to buy another Lenovo USB keyboard + mouse for it.
  2. #62
    34,370
    It's funny how a little bit of airflow can solve problems. I've got a couple of OrangePi Zero "cubes" here. One has a small 40mm 12v fan running on 5V (super quiet) and the thing runs for days (3 months so far) with a CPU temp of 50C. The other cube without the fan reads a CPU temperature of 72C and crashes within 1 day. Same software.
  3. #63
    Oct 2013
    Miami, FL
    2,533
    Yep! This is also why I insisted on double redundancy in CRACs when data centers owner by companies themselves were still around. With UPS and generator hookups for CRACs. In case a data center goes back up after a grid failure it is no use when CRACs are down. Same with not skimping on CRAC maintenance.
  4. #64
    Oct 2013
    Miami, FL
    2,533
    Cool
    After 126 turns I finally won Warlords II again. Great Roland sound track!
  5. #65
    Oct 2013
    Miami, FL
    2,533
    Cool
    Finally got the package from JP today. Both CM-300s work fine. Need to figure out how to setup the SC-88.
  6. #66
    Oct 2013
    Miami, FL
    2,533
    Question
    Removed the CR2032 from the SC-88: works like a champ!
  7. #67
    Oct 2013
    Miami, FL
    2,533
    The CM-300, SC-7 and SC-88 all sound different. I notice no discernible difference with the SC-55 map button on or off on the SC-88. The SC-88 also does not display the different instruments like you would expect with a similar SC-55(MKII/ST).
    Warlords II froze and then crashed a few times. Disabled a couple of things so hopefully there is enough conventional memory now. Very important to save before ending a turn. Fortunately with SMARTDRV that is very easy.
  8. #68
    Oct 2013
    Miami, FL
    2,533
    Turns out the SC-55 MAP button on the SC-88 is not GM related. To set the SC-88 to GM settings are required.
    https://www.vogons.org/viewtopic.php...57148&p=630483
    Need to set it every time now that there is no CR2032 installed obviously.
  9. #69
    Oct 2013
    Miami, FL
    2,533
    Cool
    Won another game of Warlords II after 128 turns this time. Back to the SC-7 because it conveniently combines SB16 and MIDI to one headset.
    Also plugged in a Pentium 166 but could not find the 166MHZ MOBO jumper without removing lots of cables and PCBs. But 150MH is pretty good already obviously.
