Results 1 to 2 of 2
Thread: MDA card with color pins?
    Default MDA card with color pins?
    Hi
    Thank You for answering in advance.
    Is this:
    https://web.archive.org/web/20200309...tow-9041323352
    a MDA card with pins that can give colour output, like first MDA from IBM?
    Best regards
    Piotr
    6,606
    Either:
    * You would need to find the schematic diagram for the card; or
    * You would need to get the owner to use a multimeter to discover if pins 3/4/5 of the 9-pin D connector are wired to an IC.
