Results 1 to 10 of 12
Thread: IBM PS/2e monitor 9507
    Sep 2016
    Shrewsbury, MA
    1,250
    Default IBM PS/2e monitor 9507
    Just got one of these monitors with a PS/2e and it's a lot stranger than I originally thought. Would this be a touchscreen monitor? If not then why does it have passthroughs for the keyboard and mouse? And it has a couple small holes to the top right of the screen, would that be a microphone?
    Feb 2017
    Guildford, U.K.
    392
    Check this out, I don't have time to research:
    http://ps-2.kev009.com/ohlandl/9533/9533.html
    Sep 2016
    Shrewsbury, MA
    1,250
    According to that it's not a touchscreen, so what could the keyboard and mouse passthroughs be for?
    Feb 2017
    Guildford, U.K.
    392
    With the M-MVA or ActionMedia II?
    Wow that's cool. Any pictures? I always wanted one of these to go with my PS/2 E.
    -I
    My Site (under construction!) | My Apple Lisa 2/10
    Sep 2016
    Shrewsbury, MA
    1,250
    Quote Originally Posted by compu_85 View Post
    -I
    I'll post some pictures soon. On my list to do while I'm stuck home is to take the PS/2e out of my kvm and set it up standalone with the original monitor, keyboard, and numpad
    http://ps-2.kev009.com/ohlandl/video/9507adjust.html
    Remember, the 9533 was "PS/2e" a power saving system. The KB and Mouse passthroughs were most likely to allow the monitor to power down
    To quote Peter Wendt, "All-plastic case with 3 catches at the front to accommodate the cable / converter box for the 9507 (that box, which detects the mouse and keyboard signals and turns on / off the screen)."
    http://ps-2.kev009.com/ohlandl/video/193-342.txt
    CONSERVATION: The IBM 9507 Color Display incorporates power
    management facilities that activate in two stages as noted, dependent
    on elapsed time since the last update of screen data
    o Quiescent mode in which screen is dimmed after 30 minutes without
    keyboard or mouse activity.
    o Power down activates after a further 15 minutes without keyboard
    or mouse activity.
    Power-down mode operates without affecting system power and does
    not cause data loss or integrity violation.
    The screen will automatically recover from either power saving
    state as a result of first use of keyboard or mouse.
    MACHINE REQUIREMENTS: The IBM 9507 Color Display is VGA compatible
    and has been tested with the IBM 9556 and 6384 system units. It is
    already announced in conjunction with the PS/2 E system unit.
    Sep 2016
    Shrewsbury, MA
    1,250
    Ah, ok. That makes sense. Pretty ingenious
    IBM sold a similar product for normal monitors, IIRC on is on Flea-Buy right now [has been for a while].
