Thread: Weitek PowerUp stickers?
    Jan 2014
    Northfield, MN USA
    229
    Default Weitek PowerUp stickers?
    I've come into a couple of Sparc 2 machines, and both have Weitek PowerUp processors in them.
    The have case stickers on the front, like this:
    https://flic.kr/p/2iGfEtU
    Mine are in the about same condition.
    Anyone have some spares they would part with, or the skills to make new ones that I could print out?
    Aug 2009
    Oslo, Norway
    1,332
    3
    Does good images of the sticker / log exist? And perhaps the measurements?
    It doesn't look like it would be too hard to whip up something reasonable in InkScape for example.
    Torfinn
    Yeah, you could pretty easily create a vector representation of that in a half-hour or so, other than not knowing what the S looked like.
    4,797
    I'd buy some! Shouldn't cost much to have them run at e.g. StickerMule, their stickers are die cut and can be any shape. I think they're all vinyl though, looks like the original was some sorta paper. They're running all sorts of specials at the moment.
    Jan 2014
    Northfield, MN USA
    229
    Here's the best picture I could get. I can't find an example on-line...
    https://flic.kr/p/2iHMah3
    Measurements are 2.5 centimeters along the right angle legs, and 3.5 cm on the hypotenuse, or 3.54 cm if you want to be all Pythagorean about it
    a fairly clean example of the Weitek logo is here.
    http://old.vgamuseum.info/vlasks-col...rporation.html
