Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Tandy Model III - Identifying 5 1/4 Drives
    Mar 2013
    Chaffee, MO
    1,444
    http://www.trs-80.org/omikron-mapper/
    The Omikron Mapper III was for the TRS‑80 Model III. Unlike the Mapper I, it only supported 5″ drives. It cost $199 in 1983.
    Usage:
    After installing the Omikron Mapper, the only visible changes were seen when starting the TRS‑80. The Omikron Mapper
    would display a short message presenting two options:
    Pressing C would boot a CP/M disk
    Pressing T would boot a TRSDOS (or any other TRS‑80 operating system) disk
    In addition, pressing T and BREAK would start Level II cassette BASIC
    Larry
    Mar 2013
    Chaffee, MO
    1,444
    I sent you several Images and the "ND80M3-3.DSK" should boot properly. The Step rate is set for
    40ms. I had a choice of 20 or 40.
    Let us know if it boots fine.
    Larry
    quite an interesting catch indeed. I say leave it as is if it works if not get a RS FDC a 360K and a FrehD and enjoy the snot out of it. CPM and TRSDOS equally.
    Gaming: i7-8700K, 16GB, 1TB SSD, RTX 2060, Dual 27" LG IPS Monitors.
    Vintage: TRS-80 MODEL 4, 128K RAM, 360K FDD, Gotek USB FDD, FreHD HDD, RS232-WIFI MODEM, DWP-510.
    Programmer: Dell Inspiron 660S i3-3220 with 16GB Ram, running a BK-844USB & EP-2A-88.
    Web Site: https://texastandyrestoration.com/
    Facebook Page: https://www.facebook.com/TexasTandyRestorations/
