Results 1 to 8 of 8
Thread: PS/2 Model 60 Hard Drive Issue
    Sep 2016
    Shrewsbury, MA
    1,245
    Default PS/2 Model 60 Hard Drive Issue
    Just picked up a nice PS/2 model 60 on ebay to use as the base for my Academic System clone. First things first I wanted to get it up and working again and check that everything is ok. Everything checks out except the hard drive isn't recognized. I have the original drive which sounds healthy but is untested and a Microscience drive that was working perfectly in the Zenith parts machine I pulled it out of. I'll likely be getting a SCSI card in the near future but for the moment I'd like to get it going with an ESDI drive. Speedstor doesn't seem to like the IBM controller very much and the bios is seeing that the controller is installed but that's it. I do have a factory PS/2 service manual that says the controller has to be matched to the drive. I have a 70mb drive and this manual is saying I need part number 72x8519 while it has a 72x8588 installed. Any suggestions? Unfortunately I don't have any other controllers on hand to try, this is my only microchannel PS/2 aside from my model 85 but that has onboard scsi so not very helpful
    Feb 2017
    Guildford, U.K.
    383
    This would be better posted in Later PCs, but have a look at Louis's site:
    http://ps-2.kev009.com/ohlandl/
    and search our NewsGroup:
    https://groups.google.com/forum/#!fo...m.ps2.hardware
    We also operate a FaceBook Group:
    https://www.facebook.com/groups/393148830747081/
    and a Sale/Trade Group:
    https://www.facebook.com/groups/1074026219362290/
    Sep 2016
    Shrewsbury, MA
    1,245
    I'll check it out. I posted it in here because it has a 286 CPU. I'd like to try low level formatting the drive and I've heard you do that in the bios with the reference disk but I'm not sure how
    Oct 2008
    Kamloops, BC, Canada
    6,000
    44
    Please do not use Speedstor.
    IBM supplies on the reference diskette the utilities needed to configure and prepare the drive. You should not require a third party program to format the disk. Verify your cabling, especially if you added a second drive. There is a DS jumper and termination resistors.
    [Need something to waste time on? Click here to visit my YouTube channel CelGenStudios]
    [No time for videos? Click here to visit my Twitter feed @CelGenStudios]
    = Excellent space heater
    Sep 2016
    Shrewsbury, MA
    1,245
    The way I have it set up is how it came to me, presumably as it was the last time it was used. I couldn't seem to find the utilities when I booted to the reference disk, where are they located?
    Feb 2017
    Guildford, U.K.
    383
    Quote Originally Posted by RadRacer203 View Post
    Links here:
    http://ps-2.kev009.com/ohlandl/8565/8560.html
    Boot to the RefDisk, press CTRL+A at the main menu, before doing anything else = Advanced Diagnostics plus Format the Hard Drive.
    Sep 2016
    Shrewsbury, MA
    1,245
    Finally managed to get into the hard drive setup, and it doesn't seem to be working. When I first turn the computer on it throws a 10480 error and when it tries to format it stops at the "checking drive parameters" screen for a while, makes one long beep, and gives up. It does seem to at least be recognizing there is a hard drive installed though. In the diagnostics it also shows no hard drive installed but I think that just means it has an issue.
    Sep 2016
    Shrewsbury, MA
    1,245
    Just figured it out- loose chip on the controller card after shipping
