Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
Thread: replacement for 80286
    Mar 2014
    San Diego, California
    Default replacement for 80286
    Ok, 2 questions....... I have an IBM AT 5170 Gen 1 (256/512 motherboard) with a 6MHz 80286. Can I just pop out the CPU and drop in a faster one ? Is so, what do you find to be the best CPU to replace it with ? The BIOS has been upgraded to the Gen 3 July 10, 1985 BIOS chips. Thanks !
    the short answer is 'no'
    IBM did make a 8MHz AT, so you might be able to convert it but IIRC there is some kind of BIOS check that prevents over clocking
    Mar 2014
    I believe the last batch of 5170s even had the 10MHz processor, but I was wondering if anyone had made the upgrade.
    4,689
    There were kits with the higher clock oscillator and updated BIOS to go along with the new CPU. Note that the 10 MHz AT variant from IBM was a bit unreliable so pushing that far might be unwise. It wasn't 5170 but I think was the industrial system.
    I was in the same boat and wanted some more performance from one of my IBM AT's. Checkout my thread: HERE Where I'm going into my way of upgrading the machine. the First thing I thought of was an Intel Inboard AT, which was specifically designed to upgrade the AT to a 386. But they are very rare and expensive. Second option would have been something like a "make it 386" or Kingston "SLC NOW!" but these options again are very rare and expensive, and may have problems with the 5170 Bios or motherboard if they aren't specifically compatible.
    My IBM 5170 in question was a 6mhz version 1 board that had an aftermarket AMI bios when i got it. So the fact that now it boots up with a phoenix bios message doesn't bother me too much. and I have to admit for about $100, it was an awesome bang for the buck upgrade.
    I mean the PS/2 Model 30 286 in "sort of" an AT 10mhz... all be it with the stupid proprietary crap that comes with it being a PS/2.
    34,098
    Quote Originally Posted by pinkdonut666 View Post
    Well, to be frank, the Model 30 isn't much of a PS/2 either...
    Mar 2014
    This is not a machine I'm keeping, but to sell. I have 2 I'm keeping, an orignal Model 339 (Gen 3 8MHz) and a wolf in sheep's clothing, a 486 motherboard in an AT case, full ISA and lots of memory. I would think a simple upgrade to 8MHz wouldn't cause too much pain, but the performance gain might not be worth it. Thanks for you thoughts.
    Jan 2005
    1,808
    The model 30/286 had a few 8 bit isa slots and no mc slots, no?
    I had 1 for a while. It looked like a ps2 to me (or PoS v.2.0 . I kind of liked the whole battleship bone color scheme. More cheery then the multinational corporate beige scheme. A twist of artsy fartsy. Even after my 30 got wet and spit sparks at me, it still worked. Built real well it seemed. But weird interleaved memory arrangement. Something screwy.
    4,689
    3 16 bit ISA slots and the world's slowest hard drive. Nice turbo AT clone except for the hard drive.
