Results 1 to 9 of 9
Thread: Failing on new Kernel for BSD2.11
    Default Failing on new Kernel for BSD2.11
    Hi Folks,
    i try to compile a new 2.11BSD Kernel on SIMH for my 11/73 ... the GENERIC without modification compile well.
    But when i change INET to YES ... i got this error:
    cc -O -DKERNEL -DGENERIC -DINET -DSOFUB_MAP -I. -I../h -o netbind ../conf/netbind.c
    ld -q -r -d -X -i -o unix.o scb.o mch_backup.o mch_click.o mch_copy.o mch_csv.o mch_dump.o mch_dzpdma.o mch_KScall.o mch_profile.o mch_start.o mch_trap.o mch_vars.o mch_xxx.o conf.o ioconf.o boot.o br.o cons.o dh.o dhu.o dhv.o dr.o dz.o hk.o ht.o init_sysent.o kern_clock.o kern_descrip.o kern_mman.o kern_proc.o kern_prot.o kern_prot2.o kern_subr.o kern_synch.o lp.o machdep.o ra.o ram.o rk.o rl.o rx.o si.o subr_rmap.o sys_inode.o sys_kern.o tm.o ts.o tty.o tty_conf.o tty_subr.o tty_tb.o ufs_alloc.o ufs_bio.o ufs_fio.o ufs_inode.o ufs_namei.o vm_proc.o vm_sched.o vm_swap.o xp.o quota_subr.o -Z sys_generic.o ufs_syscalls.o vfs_vnops.o -Z kern_acct.o kern_exec.o kern_exit.o kern_fork.o kern_resource.o -Z kern_time.o sys_process.o ufs_mount.o ufs_subr.o uipc_syscalls.o -Z dkbad.o kern_sig.o mem.o subr_xxx.o trap.o tty_pty.o tty_tty.o -Z quota_kern.o quota_ufs.o quota_sys.o ufs_bmap.o sys_pipe.o -Z clock.o dn.o init_main.o kern_pdp.o machdep2.o subr_prf.o syscalls.o subr_log.o toy.o vm_swp.o -Z ufs_disksubr.o ufs_dsort.o ufs_syscalls2.o kern_sig2.o -Z mch_fpsim.o kern_sysctl.o kern_xxx.o ingreslock.o vm_text.o -Z tmscp.o tmscpdump.o -Z -Z -Z -Z -Z -Z -Y enable34.o vers.o -lkern param.o
    ld:/xp.o: text overflow
    *** Exit 4
    Stop.
    I guess there are to much .o for the linker(ld) ???
    Dec 2012
    Colorado
    216
    I think there is a different makefile for the net kernel, did you start with that? Did you adjust the overlay segment allocation of .o files? Have a look at this old newsgroup article and see if this helps:
    https://groups.google.com/forum/#!ms...comp.bugs.2bsd
    Dec 2010
    Seattle, WA
    2,015
    Looking at some notes I have when I ran into this issue a few years ago it looks like I moved subr_prf.o from OV6 and subr_log.o from OV7 into OV5 in the kernel Makefile (maybe based on the sample CURLY configuration?) in the network enabled kernel configuration I built. This may or may not work for your configuration depending on all of the various configuration options and you may need to shuffle things around differently to get all of the overlays to fit.
    CONF=	scb.o \
    	mch_backup.o mch_click.o mch_copy.o mch_csv.o \
    	mch_dump.o mch_dzpdma.o mch_KScall.o mch_profile.o \
    NCONF=	net_copy.o net_csv.o \
    	net_mbuf.o net_scb.o net_SKcall.o net_trap.o net_xxx.o
    BASE=	br.o cons.o dh.o dhu.o dhv.o dr.o dz.o hk.o ht.o init_sysent.o \
    	kern_clock.o kern_descrip.o kern_mman.o kern_proc.o kern_prot.o \
    	kern_prot2.o kern_subr.o kern_synch.o lp.o machdep.o ra.o ram.o \
    	rk.o rl.o rx.o si.o subr_rmap.o sys_inode.o sys_kern.o \
    	tm.o ts.o tty.o tty_conf.o tty_subr.o tty_tb.o ufs_alloc.o \
    	ufs_bio.o ufs_fio.o ufs_inode.o ufs_namei.o \
    OV1=	sys_generic.o ufs_syscalls.o vfs_vnops.o
    OV2=	kern_acct.o kern_exec.o kern_exit.o kern_fork.o kern_resource.o
    OV3=	kern_time.o sys_process.o ufs_mount.o ufs_subr.o uipc_syscalls.o
    OV4=	dkbad.o kern_sig.o mem.o subr_xxx.o trap.o tty_pty.o tty_tty.o
    OV5=	quota_kern.o quota_ufs.o quota_sys.o ufs_bmap.o	\
    	sys_pipe.o subr_prf.o subr_log.o
    # OV6 gets the (hopefully) never used routines
    OV6=	clock.o dn.o init_main.o kern_pdp.o machdep2.o syscalls.o \
    	toy.o vm_swp.o
    OV7=	ufs_disksubr.o ufs_dsort.o ufs_syscalls2.o kern_sig2.o
    OV8=	mch_fpsim.o kern_sysctl.o kern_xxx.o ingreslock.o vm_text.o
    OV9=	tmscp.o tmscpdump.o
    Sep 2019
    Zurich, CH
    157
    You can check which overlay is too big by just do a size on the image.
    But it is usually overlay 6 which is too big, and I usually move toy.o to ov9 instead.
    I think we should fix this in the distribution so that people don't hit this one. Thanks for reminding me...
    Dec 2012
    Colorado
    216
    Be sure to remove any devices from your kernel configuration that you don't need.
    Here are the makefile definitions from my 11/73:
    CONF= scb.o \
    sys_pipe.o
    OV6= clock.o dn.o init_main.o kern_pdp.o machdep2.o subr_prf.o syscalls.o \
    subr_log.o toy.o
    OV7= vm_swp.o ufs_disksubr.o ufs_dsort.o ufs_syscalls2.o kern_sig2.o
    Hmm, im not sure if this error:
    ld:Xp.o: text overflow
    *** Exit 4
    is the same like this:
    vm_sched.o vm_text.o -Z kern_pdp.o kern_xxx.o ufs_syscalls2.o ufs_subr.o rk.o sys_pipe.o kern_sig2.o toy.o subr_log.o -Z -Z -Z -Z -Z -Z -Y vers.o -lkern param.o
    ld: too big for type 431
    *** Exit 2
    The ld: too big for type 431 is clear to me - overlay shuffle.
    Bur this is courious: ld:Xp.o: text overflow
    What do you think?
    Regards Henrik
    Dec 2012
    Colorado
    216
    Can you post the contents of the configuration file you are using?
    Sep 2019
    Zurich, CH
    157
    The output of "size unix" would also be interesting...
    Thks for the input.
    After some googeling, i found this: http://www.dnull.com/bsd/oldnews/bsdnew62161.html
    This helps me alot.
