Results 1 to 3 of 3
Thread: multiplication timing on 68000
  1. Default multiplication timing on 68000
    I heard that the number of clock cycles for a multiply varies depending on the number of '1' bits in one of the operands (ie. multiplication is a microcoded shift-and-maybe-add loop). But does anyone know which operand it is?
    MOVE #127,d0
    MULU #2,d0
    MOVE #2,d0
    MULU #127,d0
    Which is faster on real hardware?
    Mar 2020
    Long Island, NY, U.S.A.
    18
    Your first example would be 12 clocks faster than the second.
    The MC68000 MULU instruction requires 38 + 2n clocks where n = the number of one bits in the source operand, plus the additional clocks for the effective address calculation (in the case of immediate byte or word, 4 clocks).
    44 clocks for MULU #2,d0 (38 + 2*1 + 4)
    56 clocks for MULU #127,d0 (38 + 2*7 + 4)
  3. Default
    Thanks, that saves me from having to try running a special benchmark on the Sega or something
