Results 1 to 10 of 12
Thread: Just a warning on CRT storage, folks...
    Mar 2012
    Augusta, Georgia, USA
    756
    Default Just a warning on CRT storage, folks...
    Don't store your CRT displays long term in your basement against an earthen wall.
    The earth is a magnet... Every one of my displays is now pulled crooked in the corners depending on how they were sitting.
    Jan 2005
    1,832
    The shadow mask's have been deformed? Seems unlikely. But turn them around and leave for as long and they should be fine
    34,122
    Reminds of the trick with a compass and a room full of metal office furniture. Have someone move one of the pieces and it's possible to tell which one.
    In your case, a degaussing coil should make a difference. Most color CRTs have a degaussing coil that comes on briefly on powerup, but it's not strong enough to remove stubborn magnetization.
    Jan 2012
    Connecticut, USA
    2,720
    This problem should be easily remedied with a degausing wand though right? I dont own one but used them in the 90s. Actually i was able to degause a couple monitors woth some magnets successfuly but i woildnt re ommend that.
    Jan 2014
    Western North Carolina, USA
    1,330
    I typically use a tape bulk eraser to degauss CRTs, especially after a close lightning strike, which will rainbow every color CRT in the EMP near field.
    34,122
    What the traditional tool used is a degaussing coil:
    Those can be had cheaply made of solid ebay chinesium. Of course good luck getting one shipped in anytime soon. Invaluable resource for working on arcade cabinets, most of which do not have built in degaussing coils.
    Mar 2012
    756
    I have a good coil, I'll try it to see if it helps the convergence. I've never heard of this causing rotation... that part is really odd.
    Jan 2012
    Connecticut, USA
    2,720
    Rotation huh? Wouldnt the more likely reason be the adhesive or screwlock holding the yolk on got loose over time somehow?
    Mar 2012
    756
    Yes, the really odd thing is that they all had almost exact same issue (Model 3, 4, and a 4P) and they were still tight on the necks. I loosened them and fixed them, but I have no explanation unless somehow the coils themselves are having the magnetism altered. Fortunately, there was no image distortion other than rotation.
