Results 1 to 10 of 17
Thread: Wanted Drive Rails for mounting FDD, HDD, etc. into case
    Default Wanted Drive Rails for mounting FDD, HDD, etc. into case
    Hello,
    I am looking for a few pairs of drive rails to install drives into an AT tower. It seems like an easy enough item to find on eBay but I am having one heck of a time as my eBayfu is completely failing me. I need a minimum of three pairs and ideally five pairs but will take what I can get. Please see pictures for shape/design and sizes. TIA!
    Still looking for these. If anyone has any or ones they think may work please drop me a line!
    34,121
    How do these compare in size with the standard 5170 plastic rails? If they're the same, I've got a bunch of those.
    Good question. I don't have any 5170 rails handy to measure. Are yours easily accessible for measuring? TIA!
    Chuck,
    Looking at this picture I don't think the measurements will work out. I also don't recall how the tabs attached to the plastic rails on the 5170 anymore.
    As an aside you can now print your own plastic rails: https://www.thingiverse.com/thing:2757830
    34,121
    I can measure them, but the 5170 plastic ones look to be a bit too wide. The 5170 uses little metal clips that screw into the face that keep the plastic rails from sliding out, per your photo.
    Yeah. If I can't find something already out there I may have to go out to the shop and socially distance myself for a weekend bending sheet metal and punching holes...
    Lake Havasu City, Arizona USA
    288
    I've got these, slightly different hole configuration, but length and width look pretty close.
    1,924
    I could probably 3D print a few of those if I had a bit more information about the dimensions.
    I was thinking the same thing. I bumped into ShadowLord once before, so I know he's in my general area. I could probably print them and meet up, but I held off on offering that up because of coronavirus.
    Looking for: IBM dot matrix printer, 1986 silver badge model M, EMS ISA memory cards
