Results 1 to 10 of 22
Thread: C compilers - were there any between the first one (Unix) and the CP/M ones?
    Default C compilers - were there any between the first one (Unix) and the CP/M ones?
    I wonder about this zone of history, was there C compilers between the first one on Unix and the many that I've seen for CP/M?
    Sep 2006
    Silicon Valley
    2,243
    Whitesmiths
    34,147
    There was/is(?) a C for the Burroughs systems running under MCP, so not Unix.
    But most mainframe/mini Cs were the result of needing to host Unix. That is, the language was not selected on its own merits. One might as well talk about FORTH for the Cray X-MP.
    Compared to most mainframe HLLs of the time, C was pretty anemic. I admit that I wasn't taken with K&R C all that much. It wasn't until much later that C standardized on some important features.
    Jan 2014
    Western North Carolina, USA
    1,332
    There was DECUS C back in the late '70s for DEC minis. I think I read that it was first released in 1978. Hmmm.... https://manualzz.com/doc/19806580/th...se--second-...
    34,147
    Document says 1983, so after CP/M's heyday, no?
    4,694
    The version of DECUS C I looked at has a CC.DOC from 15-OCT-81 which has an appendix A that lists CBUGS.DOC of 17-SEP-80. Presumably to have a buglist, there would have had to be earlier versions.
    Jan 2014
    1,332
    In the document at the link I posted, see page 8, section 10.0: "Decus C was first distributed to the "wider world" on an RSX-11MSIG tape in 1978. It was first distributed to Decus --as11-SP-18 --in November 1980."
    34,147
    Given that CP/M was 1974, I wonder if the cited on qualifies as "between Unix and CP/M"...
    4,694
    Given the query involved C compilers, that should give a range between 1973 when C on Unix appeared in public and 1979 when BDS C for CP/M appeared or perhaps a few years later when C compilers for CP/M implemented a larger portion of C.
    34,147
    I suspect that BDS C wasn't the first C for CP/M.
