Results 1 to 10 of 11
Thread: .IMD to .DSK conversion for RX01 disk
    Default .IMD to .DSK conversion for RX01 disk
    I have a RX01 disk from which I want to make an image.
    So I made an image trough IMD. But I now want to convert the file
    to a binary .DSK file so that I can use it in an emulator.
    I found several conversion tools but they are all from 'something' to IMD.
    But I don't see any option to get from IMD to a binary .DSK file... Any idea's?
    Regards, Roland
    ...Not the answer you asek for, but if you are able to read the disk, can you read the disk with putr.exe? It's a DOS tool. This will write as .DSK.
    Oh I tried it with Putr but I must have done something wrong.
    If it works with Putr then my problem is solved.
    Any examples on how to make such an image?
    I will have a look in my note in the evening.
    Regards, Roland
    Do you know the format of the .DSK file? Is it just a raw sector dump by any chance?
    I have played with the .IMD file format and can convert it to a raw image.
    Dec 2010
    Seattle, WA
    2,020
    Regards, Roland
    If you were able to run IMD118 to create the .IMD image file, then you can also run IMDU to create a raw sector file.
    IMDU <input .IMD filename> /B <output .DSK filename>
    An RX01 disk has logical sector interleave and skew applied to the raw physical sectors. If you use PUTR to access the disk image file it has a "dxilv" routine in the source code (PUTR.ASM) which I think should deal with that.
    	subttl	interleave
    ; RX01 interleave routine.
    ; bp	logical device rec
    ; ch	cylinder (0-75.)
    ; cl	logical sector (0-25.)
    ; On return:
    ; ch	cylinder (1-76.)
    ; cl	sector (1-26.)
    ; From RT-11 V04 DY.MAC:
    ; ISEC=(ISEC-1)*2
    ; IF(ISEC.GE.26) ISEC=ISEC-25
    ; ISEC=MOD(ISEC+ITRK*6,26)+1
    ; ITRK=ITRK+1
    ; PDP-8 interleave is the same but there's no skew.
    dxilv:	add	cl,cl		;sec*2
    	cmp	cl,ss:nsecs[bp]	;off EOT?
    	jb	dxilv1
    	sub	cl,ss:nsecs[bp]	;start over at 1
    	inc	cx
    dxilv1:	cmp	ss:wsize[bp],16d ;PDP-11 disk?
    	jne	dxilv2		;no, no skew
    	mov	al,6		;skew factor=6
    	mul	ch		;*track
    	add	al,cl		;add (sec-1)
    	adc	ah,0
    	div	ss:nsecs[bp]	;track size
    	mov	cl,ah		;get remainder
    dxilv2:	add	cx,101h		;track,,sector +1
    	ret
    Ah thanks a lot! That works
    Regards, Roland
    so just for the records, if you will do the dsk image with putr:
    The disk is in drive b:
    format filemname /rx01 /os8
    mount aa: filename /rx01 /os8
    mount b: /rx01
    copy/dev/bin b: aa:
    dir aa:
    dismount aa:
    With putr you can make very batch similar processes with command files and a putr.ini file in the directory you start putr. But you have to read the manual for that.
    Have fun
    Volker
    Quote Originally Posted by gnupublic View Post
    mount b: /rx01
    copy/dev/bin b: aa:
    dir aa:
    dismount aa:
    Have fun
    Volker
    Hi Volker,
    Thanks, good to know how it works on putr!
    Regards, Roland
    Aug 2009
    Oslo, Norway
    1,350
    3
    FWIW, there is also imd2raw http://bitsavers.org/bits/Convergent/ngen/imd2raw/
    It's a C program, compiles lots of places
    Torfinn
