Results 1 to 10 of 11
Thread: Circumventing Windows 2000 Password
    Default Circumventing Windows 2000 Password
    Hi Guys,
    I got a call yesterday asking me if there was some way to get around Windows 2000 asking for a password during startup. Here's the issue:
    There is an old scanner which has no drivers for any recent OS. The old scanner is needed because it will do things which newer scanners will not. The scanner used to be on the the Windows 2000 machine but it has not been used for so long any passwords are forgotten. So when it was time to boot it up, the prompt for a password appeared and stalemate.
    Obviously the machine could be reloaded from scratch but if the scanner drivers are no longer available it wouldn't do much good. And if the machine cannot be booted, there's no chance to run Double Driver (if it works for W2000) to extract the drivers beforehand.
    I guess one option is to boot the machine to Win XP using Hiren's Boot CD, extract the drivers and then reload with Win 2000. But maybe there is an easier way.
    I know many of you eat and breath this stuff, but with the little time I spend with computers now, I may be forgetting more than I remember. So if there are any ideas out there, please let me know.
    Thanks...Joe
    There are CD's you can boot from that will load the registry and either blank or set the password.
    Something like this: http://pogostick.net/~pnh/ntpasswd/bootdisk.html
    Oh and since you mentioned Hirens boot CD, it looks like that will do it too: https://www.hirensbootcd.org/howtos/
    Sep 2008
    SE MI
    4,746
    6
    Quote Originally Posted by Grandcheapskate View Post
    Hi Guys,
    Thanks...Joe
    Real long shot: Try booting into the "Safe" mode (F and see if that lets you in. If so, go to 'User Accounts' and attempt to reset the P/W.
    What is the scanner?
    New Zealand
    4,164
    4
    Ultimate boot disk CD. Clears old passwords in NT based windows.
    yeah it's a trivial task with Hiren's
    Sep 2008
    SE MI
    4,746
    6
    Yeah, I've used a unix-based boot CD (or floppy) to clear the password. This program works on any windows NT,W2K,XP and later. My advice is to reset the Administrator password and set it to blank (nothing). It gives the choice of setting the password to something else, but I've found it doesn't work.
    Once you're in, you can patch the registry to set a default user logon and password, and it will auto-login upon boot. You'll never have to worry about it again.
    Oct 2016
    Burnley, UK
    290
    This is what I've always used:
    https://trinityhome.org/
    Sep 2008
    SE MI
    4,746
    6
    Quote Originally Posted by Robbbert View Post
    I always set the Windows password to "password" for personal use inside my home and away from prying eyes..
